Tell me more ×
Is connecting a higher-amp (e.g. 2 A) adapter to a lower-amp (e.g. 1.3 A) electrical device safe?
I wonder if it will cause the adapter to over heat and cause fire or cause damage to the electrical device.
share|improve this question
I already voted to close, but I think this is a better question to be a duplicate of: electronics.stackexchange.com/questions/16422/… – Kellenjb Jun 17 '12 at 16:48
@Kellenjb, don't know why, but your comment is hilarious :) – abdullah kahraman Jun 17 '12 at 17:34
closed as off topic by Olin Lathrop, W5VO, Kellenjb, AndrejaKo, Kortuk Jun 17 '12 at 22:07
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
1 Answer
No it won't overheat the adapter. That's designed to deliver up to 2 A, and everything less than that is safe. If you disconnect the device the current will be zero, and that's also safe. The adapter will supply the required current, not the current it can supply.
Never do the inverse: connecting a 2 A device to a 1.3 A adapter, though.
share|improve this answer
