Tell me more ×
I have two lead-acid batteries connected in series to produce 24V. They are powering an audio amplifier.
I'd like to be able to charge them while they are powering the amplifier, with solar panels. Can I connect a solar panel in parallel to each battery, separately?
I made a drawing to illustrate what I'd like to achieve:
share|improve this question
1 Answer
up vote 5 down vote accepted
Yes, you can charge each battery independently from separate solar panels as long as each is electrically isolated.
However, it would make more sense to combine the panels and charge the whole 24 V battery as one. Lead-acid batteries are fairly forgiving, especially in that you can charge them with a current-limited voltage supply. A 12 V battery can be held indefinitely at about 13.6 V without harm. It will draw some charge current at that level, but this current won't do long term harm even if the battery is already fully charged.
A power supply that takes the solar panel output and makes the roughly 27.2 V output should work fine. The more cells in series, which in this case is 12 instead of the usual 6 of a "12 V" battery, the more you have to worry about cell imballance. You might therefore want to be a bit conservative with the float voltage and/or make the current limit lower than usual. The easiest way to do that is to size the solar panel such that it simply can't produce enough power to hurt the battery in full sunlight. Then the power supply only needs to try to produce about 27 V, but fold back as necessary limited by the power from the solar panel. This scheme will give up fast charge time, but if that is not a issue it's intrisically safe operation makes things easier.
share|improve this answer
Thanks, Olin. When you say "as long as each is electrically isolated", that means I can't charge them while they are powering the amplifier, right? Like on the drawing I made. – Wurlitzer Jun 17 '12 at 18:24
@Wurlitzer: No, that means the solar panels can't have a common ground or something. It is perfectly fine to have them charge the batteries while the batteries are being used. – Olin Lathrop Jun 17 '12 at 19:39
@OlinLathrop: you closed my question ( electronics.stackexchange.com/questions/36281/… ), on the base of that being identical to this. So let me ask here the question. What if I have a single 12V panel. Can I attach it to a "controller" (I gather) that switches and recharges one and then the other 12V battery? Thanks. – Pietro Speroni Jul 23 '12 at 13:51
@Pietro: You could as long as the switching is break-before-make. Also the whole controller must be isolated (floating) compared to the system being powered. That would be the case if it only connects to the solar panel and not a external ground. – Olin Lathrop Jul 23 '12 at 14:27
discard
