Tell me more ×
I recently purchased this wireless camera, and I'm trying to figure how to boost its signal. I thought about making the antenna on the receiver longer and/or increasing the voltage running through the camera (would that fry the camera?). How much could I increase the voltage and keep it safe? Would increasing the length of the antenna on the camera help?
Any help is appreciated. I have soldering and basic EE experience so I'm ready to modify if necessary.
Thanks!
PS What type of wire and connection (e.g. soldering, clips, etc.) do I need to create an antenna?
share|improve this question
Consumer support is off topic, sorry. However a higher voltage will not help(unless they somehow used a chipset that can use that, I would bet it is regulated before the chipset for RF amp). An antenna with a higher gain will give you better range but you are probably better off purchasing one. – Kortuk Jun 17 '12 at 20:18
I actually like this question. Maybe go and support "Hacking" in Area51: area51.stackexchange.com/proposals/40927/hacking Oh, and buy a directional antenna; I have this one and it does as you seek goo.gl/qdr70 – Chris K Jun 17 '12 at 20:49
@ChrisK, sounds like a good idea. The issue here is the best answer is something that does not approach design. Hacking is a great place to offload most of our consumer electronics questions. – Kortuk Jun 17 '12 at 22:10
I still think it's valid. I was intending to take it apart and modify the contents, which could include an amplifier. That's a bit different than just buying new parts. Also, longer antenna on receiver: does that help? or just waste of wire? – Jason Jun 17 '12 at 22:24
Just lengthening the antenna won't work, it will reduce the range. – Leon Heller Jun 18 '12 at 1:59
show 3 more comments
closed as off topic by Kortuk Jun 17 '12 at 20:17
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
