Tell me more ×
Am using a EMG30 geared motor with MD25 drive to Arduino.
i would like to control the motor through digital pins am looking at the example done but James Henderson.
link is below:
http://www.robot-electronics.co.uk/htm/arduino_examples.htm#MD25%20RD02%20Motor%20Controller
Title:
"MD25 RD02 Motor Controller Serial"
i can't get the example code to work, can anyway tell me if the example code is wrong.
example code:
*   Arduino MD25 example codeArduino MD25 example code          *
*               MD25 running in serial mode                     *
*                by James Henderson 2012                        *
#include <SoftwareSerial.h>
// Values of 0 being sent using serial.write() have to be cast as a byte to stop them being misinterpereted as NULL
// This is a bug with arduino 1
#define CMD                 (byte)0x00              //  MD25 command byte of 0
#define WRITESP1            0x31                    // Byte writes speed to motor 1
#define WRITEACCEL          0x33                    // Byte writes a value of acceleration
#define RESETREG            0x35                    // Byte resets encoders
#define SETMODE             0x34                    // Byte sets mode
#define READIVS             0x2C                    // Byte reads motor currents and battery voltage
#define READENCS            0x25                    // Byte reads both encoders
#define GET_VER             0x29
#define LCD_RX              0x02                    // RX and TX pins used for LCD0303 serial port
#define LCD_TX              0x03
#define LCD03_HIDE_CUR      0x04
#define LCD03_CLEAR         0x0C
#define LCD03_SET_CUR       0x02
SoftwareSerial lcd03 = SoftwareSerial(LCD_RX, LCD_TX);          // Define the serial port for the LCD03
long encValue = 0;
byte softwareRev = 0;
void setup(){
  Serial.begin(38400);
  lcd03.begin(9600);
  Serial.write(CMD);                                            // Set MD25 accelleration value
  Serial.write(WRITEACCEL);
  Serial.write(10);
  delayMicroseconds(10);                                        // Wait for this to be processed
  Serial.write(CMD);                                            // Reset the encoder registers to 0
  Serial.write(RESETREG);
  Serial.write(CMD);                                            // Set mode to 2, Both motors controlled by writing to speed 1
  Serial.write(SETMODE);
  Serial.write(2);
  Serial.write(CMD);                                            // Get software version of MD25
  Serial.write(GET_VER);
  while(Serial.available() < 1){}                               // Wait for byte to become available
  softwareRev = Serial.read();
  lcd03.write(LCD03_CLEAR);                                     // Clear the LCD03 screen
  lcd03.write(LCD03_HIDE_CUR);                                  // Hide the LCD03 cursor
void loop(){
  while(encValue < 3000){               // While encoder 1 value less than 3000 move forward
    Serial.write(CMD);                  // Set motors to drive forward at full speed
    Serial.write(WRITESP1);
    Serial.write(150);
    encValue = readEncoder();
    readVolts();
  delay(100);
  while(encValue > 100){
    Serial.write(CMD);                  // Drive motors reverse at full speed
    Serial.write(100);
    readVolts();
  delay(100);
long readEncoder(){                        // Function to read and display the value of both encoders, returns value of first encoder
  long result1 = 0;
  long result2 = 0;
  Serial.write(CMD);
  Serial.write(READENCS);
  while(Serial.available() < 8){}          // Wait for 8 bytes, first 4 encoder 1 values second 4 encoder 2 values
  result1 = Serial.read();                 // First byte for encoder 1, HH.
  result1 <<= 8;
  result1 += Serial.read();                // Second byte for encoder 1, HL
  result1 <<= 8;
  result1 += Serial.read();                // Third byte for encoder 1, LH
  result1 <<= 8;
  result1  += Serial.read();               // Fourth byte for encoder 1, LL
  result2 = Serial.read();
  result2 <<= 8;
  result2 += Serial.read();
  result2 <<= 8;
  result2 <<= 8;
  lcd03.write(LCD03_SET_CUR);              // Set the LCD03 cursor position
  lcd03.write(21);
  lcd03.print("Encoder 1:");               // Displays data to the LCD03 screen
  lcd03.print(result1,DEC);
  lcd03.print(" ");                        // Print a blank space to clear any unwanted characters that are leftover on the LCD03 display
  delay(5);                                // Delay for LCD03 to process data
  lcd03.write(41);
  lcd03.print("Encoder 2:");
  lcd03.print(result2,DEC);
  lcd03.print(" ");
  return result1;
void readVolts(){                                                 // Function reads current for both motors and battery voltage
  byte batteryVolts, mot1_current, mot2_current = 0;
  Serial.write(CMD);
  Serial.write(READIVS);                                          // Send byte to readbattery voltage and motor currents
  while(Serial.available() < 3){}                                 // Wait for the 3 bytes to become available then get them
  batteryVolts = Serial.read();
  mot1_current = Serial.read();
  mot2_current = Serial.read();
  lcd03.write(61);
  lcd03.print("Mot1 I:");
  lcd03.print(mot1_current,DEC);
  lcd03.print(" Mot2 I:");
  lcd03.print(mot2_current,DEC);
  lcd03.print(" ");
  delay(5);
  lcd03.write(1);
  lcd03.print("Rev:");
  lcd03.print(softwareRev, DEC);
  lcd03.print(" ");
  lcd03.print("Volts:");
  lcd03.print(batteryVolts/10,DEC);                               // Seperate whole number and descimal place of battery voltage and display
  lcd03.print(".");
  lcd03.print(batteryVolts%10,DEC);
  lcd03.print(" ");
share|improve this question
Know someone who can answer? Share a link to this question via email, Google+, Twitter, or Facebook.
discard
