I just got my brand new LiPO battery charger. It is require 12 volt pover supply. I saw people are using car battery, pc power supply to this charger 12 V. but i'm not sure about current it is require.
Here is spec:
Operating voltage range: 10.0~18.0Volt
Circuit power: max.50W for charging, max.5W for discharging
Charge current range: 0.1~5.0A
Discharge current range: 0.1~1.0A
Current drain for balancing Li-po: 300mAh/cell
NiCd/ NiMH battery cell count: 1~15cells
Lithium battery cell count: 1~6Series
Pb battery voltage: 2 to 20V
Dimension: 135×100×40mm
Will it be ok if i use for power supply plug in transformer which outputs 12 VDC, 800mA?
Dont wanna damage any of them.
