I have 4 speakers wires:
- left red wire
- right red wire
- left black wire
- right black wire
Like this:
I want to take those 4 wires, and make a 3.5mm stereo RCA plug for my iPod. So that I will be able to play the songs from my iPod to the speakers.
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
Your iPod was designed to drive headphones, not speakers. It outputs a line-level signal which just carries signal. It has no power to drive a speaker. http://en.wikipedia.org/wiki/Line_level You need to send the signal from your iPod to either an amplifier or a powered set of speakers. Both of which will probably take a 3.5mm directly. But just for information's sake, there are many different "flavors" of 3.5mm jack. And if you were to connect speaker wire to a 3.5mm jack for whatever reason, how it gets connected depends heavily on which type of jack you are using. |
