I am having a control panel to operate a green house fan and pad lab. in this lab i am having,
- 2 fans
- 1 temperature sensor(PT-100)
- 1 humidity sensor
- 1 motor for water flow(2 HP)
- 1 motor for fogger (1.5 HP)
In the control panel are the following components:
- MCB 6A TP- 5 Quantity
- Temp. controller- 2
- Humidity controller- 2
- contactor 9A- 5
- overload relay 1.6-2.4A- 3
- overload relay 2.5-4A 2
- PLA relay- 2
- E push button stop- 1
- Selector switch- 5
The issue is that when the motor starts the overload relay is getting trip after each 5 minits. The motor needs to run continuously. So my question: Is there any problem with the rating of the overload relay? If so then what should be the rating of the overload relay?
