Background: I'm working on a project that would allow a number of people to hook up their laptops to a single monitor through a KVM and use buttons on the desk to control who has control of the monitor. Originally, the plan was to use buttons with microcontrollers to send keyboard shortcuts to the KVM which would then switch to a given input based on what keyboard shortcut was sent. I've run into a problem because the keyboard switching is a little.. off. The only way to do it without installing software is to cycle through the inputs 1 by 1, and it's a requirement that the user not need to install anything. So now I'm wondering if its feasible to interact directly with the KVM hardware. Worst case scenario, we could just plant the KVMs on the table, but that's not quite as user-friendly.
Problem: I want to have a bunch of buttons on a table, ~6ft away from the KVM, which would replace the buttons on the KVM board. I'm not sure how to do this, but I have a few ideas (not sure if they're feasable):
- Remove the buttons and solder wires in their place, which would be connect to the buttons on the table.
- Connect the wires from the table buttons directly to the leads of the buttons on the board, without removing them.
- Some kind of tiny motor or something that could push the buttons on the KVM. (Rather avoid this)
So I guess the question is: which of these would be the easiest, and what's the best way to go about it? Also open to suggestions on entirely different solutions..
First picture is of the top of the KVM, where the buttons are soldered onto the board, the second is the underside of the board. The button connections can be seen sticking out of the board.
