I have the circuit below and I have to calculate complex current i1using thevenin equivalent circuit method:
I tried to follow the rules and open the terminal AB across the resistor:
I want to ask if this is a correct way to convert the circuit to thevenin. Also I am not sure is capacitor's reactance -4iis same as -4j or 4, 90 degree ?
Then The voltage across AB terminal would be equal to voltage across the capacitor? Is it ok to in this case see the voltage source as a short?
