Dosing pumps means pumps that dose a specific amount with a high accuracy. In many process control scenarios, level gauges or flow meters are used (with low accuracy, at least in some cases), what other strategies are widely used? Sources/Examples would be appreciated.
Edit 2012-07-19
My questions are, what measurements are taken (if any), how are the diverse inexactitudes accounted for and where along the drive train do you control the pump (FI-controlled motors vs. just turning off after Volume X is pumped, for example)
I can imagine a lot of ways to do this, but I don't know why one way may be superior to another in a given situation.
