Tell me more ×
This is not homework. I have this circuit, and I want to calculate V2. I know it is equal to V1 at t=0, and equal to \$V1 \cdot \frac{R2}{R1+R2}\$ at t=\$\infty\$, but I don't know how to calculate the charging of the capacitor.
All I find on Google is charging of an RC, without the parallel resistor.
share|improve this question
en.wikipedia.org/wiki/Th%C3%A9venin%27s_theorem Thevenin says R1 and R2 are in parallel and the voltage is relative to the resistor divider. Is that hint enough to get you going? – jippie Jul 8 '12 at 14:41
up vote 3 down vote accepted
The answer is in Thévenin, like Alfred and jippie also suggested. Thévenin claims that any 1-port network consisting of voltage sources and resistors can be replaced by a voltage source and a series resistor across that port, and who am I not to believe him?
Let's consider your circuit without the capacitor and assign its connections as the circuit's port.
First we look for \$V_{th}\$, which we do by leaving the output open-circuit, so that \$R_{th}\$ can't cause a voltage drop. Then R1 and R2 form a voltage divider with \$V_{AB}\$ = V1 \$\times\$ R1/(R1 + R2) = 3 V. (I'm using actual values for voltage and resistors to make it more graphic.) That's \$V_{th}\$. Fine.
Next we have to find \$R_{th}\$. You can do that by shorting all voltage sources and measure the resistance between A and B. But let's do it the alternative way: short-circuit A to B, and measure the current through that point. That should be \$V_{th}/R_{th}\$. Both methods give the same result, and it depends on the kind of circuit which way is best.
So shorting A-B we get I = V1/R2 = 12 V/ 12 Ω = 1 A. (What a coincidence! :-)) Then \$R_{th}\$ = 3 V/ 1 A = 3 Ω. If we now reconnect our load we have the typical RC circuit where C1 is charged via a series resistor (let's say C1 is 1 F):
\$ V_C(t) = V_\infty + (V_0 - V_\infty) e^{\dfrac{-t}{RC}} \$
\$V_\infty\$ is \$V_{th}\$ because after C1 is charged there won't be a voltage drop across \$R_{th}\$. And \$V_0\$ is 0, we start with an uncharged capacitor. Then
\$ V_C(t) = 3 V + (0 V - 3 V) e^{\dfrac{-t}{3 s}} =3 V (1 - e^{\dfrac{-t}{3 s}}) \$
And that's the well-known charging equation.
The blue curve is the voltage between A and B, the purple curve is the voltage at B with respect to ground.
share|improve this answer
Haha! Nicely explained and was really funny. I got a little lost when you have posted both the thevenin circuit and the original circuit without the capacitor, but then I recovered quickly. – abdullah kahraman Jul 9 '12 at 21:40
@abdullah - Funny??? Not the exponential, I hope :-) – stevenvh Jul 10 '12 at 4:15
lol. what happened to the exponential ? :) – abdullah kahraman Jul 10 '12 at 6:44
There's always more than one approach to solving a circuit problem but the approach I generally find most useful in this type of problem is to find the Thevenin equivalent resistance \$R_{TH}\$ "seen" by the capacitor. This will allow you to find the time constant, \$\tau = R_{TH}C \$.
To find the Thevenin resistance, remove the capacitor and zero the voltage source (replace with wire). Now, find the resistance between the terminals where the capacitor connects; that resistance is \$R_{TH}\$
If you've already found the voltage across the capacitor at t = 0 and t = \$\infty\$, just "connect them together" with the exponential function:
\$v_C(t) = [v_C(\infty) - v_C(0)](1 - e^{t/\tau}) + v_C(0)\$
For \$v_C(0) = 0\$, this simplifies to:
\$v_C(t) = v_C(\infty)(1 - e^{t/\tau})\$
Now that you have \$ v_C(t)\$, you have \$v_2(t) = V_1 - v_C(t) \$
discard
