What is the extra, 5th, pin on micro usb 2.0 adapters for?
Here is an image with the different connectos. Most of them have 5 pins, but the A-type host only has four.
What is the extra, 5th, pin on micro usb 2.0 adapters for? Here is an image with the different connectos. Most of them have 5 pins, but the A-type host only has four.
It's for On-The-Go, to select which device is the host or slave:
It's for host:client negotiation.
As shown here the original type A and B connectors use four connections, D+ and D-, which are differential data signals, along with ground and +5v. The newer mini and micro connections add an ID signal. |
