I'm ordering an Ethernet Shield for a project I have planned, but before make the investment, I want to make sure the project will work. Eventually it will communicate with a website via ethernet, but I was wondering if I could test this through my PC, using it simply to route page requests, so that I can easily adapt it for the ethernet shield.
Tell me more
Electrical Engineering Stack Exchange is a question and answer site for
electronics and electrical engineering professionals, students, and enthusiasts. It's 100% free, no registration required.
I'm not sure if the Arduino can do it, but you can look at the possibility of implementing SLIP. It's designed to layer TCP/IP over serial communications. You can configure a PC as the SLIP server, for the device to login and route packets through. Edit: Turns out there's an Arduino SLIP library that does that exactly! |
