I did a big cleanup of my collection of parts today and I now have a big pile of parts on my desk (the majority of which is resistors). My previous method of finding the resistor value I wanted was to look through my little box and read the colour codes. Unfortunately I now have a lot of resistors, making an individual search almost impossible. Instead of reinventing the wheel, I put it to you my fellow chiphackers: do you know of any efficient (as in fast recall) ways to store and categorise components ?
I understand you can get lots of small drawers but it seems like such a waste of space to put only a single resistor of an unusual value in its own drawer.
link|improve this question
I got a kit of resistors so I wouldn't need to hunt through them anymore. Each value was in a little unlabeled bag, so I still had to hunt through them and read the color codes. >:( – endolith Jul 18 '10 at 14:57
Don't overestimate the size of the storage cabinet required. Especially if you subdivide by depth, you can stock a lot of components. For example, if you're stocking 5% resistors, you only need 3 rows of 8 bins, divided into 5 categories (<100, < 1k, <10k, <100k, <1M) to stock every resistor from 1 ohm to 910k. – Kevin Vermeer Jul 18 '10 at 23:41
Plus colour codes are quick to read if you've stocked by magnitude. Say you want 47k, look at the 10k-100k box/bag for something with purple (7) and once you have a few, you can check if they're what you want. – XTL Jul 20 '10 at 15:00
Oh man, if only I had an answer to this question... It's like the effort involved in keeping things organized is more expensive than the parts themselves. – endolith Oct 12 '10 at 1:18
I think the question you need to ask yourself first is this: ** Is sorting the resistors worth your time**. Resistors are so dirt cheap that whenever I drop a few, or mix up my bins, I typically toss them, because I can replace all the lost resistors for ~$2.50, and it would take me more than an hour or two to sort them. Are you only worth $1.25 an hour? – Fake Name Feb 27 '11 at 4:12
show 4 more comments
feedback
I keep resistors in drawers organized by the first digits of value.
R-1, R-12, R-15, R-18, R-22 and so on. (same for capacitors)
R-1 contains 100ohm, 1k, 10k... R-22 contains 22ohm, 220ohm, 2.2k, 22k...
link|improve this answer
If that still proved too much of a problem I suppose you could get some small plastic bags and subdivide each drawer further. – Amos Jul 18 '10 at 8:55
I think David L. Jones commended this storage method. – J. Polfer Oct 11 '10 at 17:29
I bought a 1000-piece resistor kit that came with each value in a little bag with no labels. >:( I just spent a long time writing the value on each bag and sorting them by first digit. There are more 1s than 9s, though, so my meta-grouping ended up being 1.0-1.2, 1.3-1.9, 2_, 3_, 4_-5_, and 6_-9_. – endolith Mar 6 '11 at 0:42
The point is to sort resistors by the first two bands (the first two digits). So each value in the same drawer differs only by the third band (that is the "number of zeroes" after first two digits) and it's easy to discriminate between values. – Axeman Mar 9 '11 at 14:38
feedback
I don't do anything but prototype work and 5-10 run prototype assembly here so i don't keep that many parts around but here are my thoughts:
For SMD: This is about my favorite thing ever created I also have one of these for low volume stuff that comes on tape and is useful for testing, ferrite beads and such.
For ICs / connectors: I don't really reuse a lot of this stuff from design to design so they are normally just kept in their digikey/mouser bags and kept in the project box with the PCB's and connectors etc. I'm fairly good at keep a running inventory of what i have and what project it was for on my workstation so i can usually find this stuff quickly.
For Through Hole: I really don't use this stuff much. I have a fishing box style assortment of ceramic caps, 1 of 1% 1/4W resistors, 1 of aluminum caps, and 1 full of other stuff, diodes and transistors, etc. I don't really use this very often with the exception of a resistor or cap here and there if i need to blue wire something onto an early rev design. This could definitely be better organized.
That SMD binder is awesome! I was just looking for something like that last week! I'll definitely be getting a few. Thank you! – pingswept Jul 18 '10 at 19:46
feedback
I use a Raaco assorter
Raaco Assorter
+1. Very good! You can take it wherever you want. – Daniel Grillo Feb 26 '11 at 21:57
I use many of these Raaco for Lego Technic pieces... they're great. – Axeman Mar 9 '11 at 14:39
feedback
If really pressed for space, I think I'd lump everything 100 ohms and under in one bin, everything 1M and above in another, then one bin each for 100-1K, 1K-10K, 10k-100k and 100k-1M, but those things with all the little drawers are very cheap and easy to come by.
feedback
For through-hole parts I use something like this:
http://www.amazon.com/gp/product/B000CRHD6K/ref=oss_product
You can find a list of standard resistor values here: http://www.rfcafe.com/references/electrical/resistor-values.htm
Then just start making labels (color-coded labels in excel work great - put the color code on there for your reference). In fact I have the labels I made with color codes. I think if everything still works right after uploading to Google Docs that these should print out on mailing labels - maybe two or three to a label?
http://spreadsheets.google.com/ccc?key=0AlW3tzPu0DsLdHVtZHBmc1pKajdfSUtoSG8ySjI5dVE&hl=en&authkey=CMS268gM
feedback
I keep mine in small labeled envelopes (hand-written), with each decade in a labeled larger envelope, and keep them all in a cardboard box. I have every value from 1R0 to 10M0 (1% metal film) stored that way.
I ought to sort the small envelopes before putting them back in the large envelope, to save time finding a particular value, but I don't bother.
feedback
We keep our through-hole resistors in small ziplock bags, and keep those bags in baseball card organizer pages (the plastic loose-leaf pages with nine pockets on each side). All of them fit in a three-ring binder. Whenever we need a particular value, we just page through the book. We also add a little card to each pocket with the value that belongs there, so we know what to restock when we're out.
The downside is that if you turn the book upside down you're going to make a huge mess, but amazingly enough, in the two years we've been using this system that hasn't happened once.
And on July 21, 2010 someone turned the book upside down... – Simurr Feb 5 '11 at 5:59
I also do this, without the ziplock bags. The card holders are tight enough, that I have never had a problem with them falling out. I do keep it on a shelf above my bench and am careful not to invert it, but I don't think it would be disastrous if I did. – CMP Sep 19 '11 at 22:30
feedback
For TH and larger parts I use lots of small drawers. I also use the Akro-mils cabinets with dividers. http://www.amazon.com/gp/product/B00018AR5Y/192-5968131-0652527 These are nice because you can different draw sizes in a 17"x11"x11" cabinet. Very expensive unless you can find them surplus.
For SMD components I use a combination of stainless steel tins and watchmakers tins. I built some low-profile trays that hold the tins. See http://www.luciani.org/no-place-to-go/comp-storage/index.html
One very nice thing about the tins is they are small. For most designs you can kit up the different components on your bench.
feedback
I've been contemplating a system using labeled envelopes, but I haven't actually done it yet.
feedback
I use glassine envelopes and keep them organized with little tab dividers. They're cheap enough to have one for each value and expandable enough to hold all of my SMD and most of my through-hole components.
feedback
I've put some of the passives in ziplock type freezer bags. They're transparent and you can write on them easily. Minigrip brand mini bags are about 10x10cm and I could file them in an old floppy disk organizer box. It's not quite ideal, though. Fresh resistors and diodes are kept in those "belts" as long as the glue holds and SMD's are in their tapes.
I found a source for surplus lot of those plastic boxes (also transparent) with lots of little compartments. I put a piece of tape on each with a number and have kept a small database that tells me what chips to find in which box and how many I have. Those boxes are nice in that they protect parts mechanically. They tend to be horribly expensive, though.
I also have some IC tubes and (Maxim's sweet sweet snappy) sample containers, ESD foam etc that I've gathered over the years that I can store stuff in.
And finally there's a few small drawer units from Ikea that I keep tools, batteries and solder/wick/flux/paste etc in.
I absolutely hate those "organizers" that shops use with the metal frame and hard plastic drawers that gather dirt, waste space, rattle and every now and then spray all the contents on the floor when you open a drawer quickly and the stop catches and it does that magic slip and flip.
There's probably no single container to end all containers.
I hate that magic slip and flip. – Kevin Vermeer Jul 20 '10 at 20:09
feedback
Personally I use the same thing I've used ever since I was a kid; a little "cabinet" full of plastic drawers. You see them at any hardware store for holding nails and screws and nuts and bolts. Cheap and works pretty well, although if the cabinet tips you're in for a bit of a job.
I organize them numerically; Starting with the smallest capacitors (1-50pf, 51-500pf, 501-999pf, etc.) in whatever "jump" works. e.g. I only seem to use 4.7pf, 22pf, 47pf and 100pf caps in that range, so they all go in one bin. I have 0402, 0805, 1206 and through-hole caps in the same drawer, unless the TH parts are big. It's really not that big a chore to pull out a drawer and look for the right package.
For "common" values (0.01uF, 0.1uF, 10uF, etc.) they each get a drawer all to themselves, usually with the through-hole variety in their own drawer. I find I buy 500 of the one kind of cap, and just the SMT size takes up most of the drawer.
I do the same with resistors and inductors.
For semiconductor devices, I have all the small-signal diodes in one drawer, all the zeners in another, all the rectifiers in another (again, with TH in their own drawer becuase they're big)... I have a drawer each for red, green, yellow and blue LEDs, and my NPN and PNP transitors get separate drawers too.
Solder and angel-hair wire (I actually use "bare" (bus) 30AWG wire and 26 or 28AWG nylon tubing) go on threaded rods which sit in a holder made out of angle-iron. THis lets the spools turn and keeps the spools out of the way.
I think I'll end up putting all the through-hole devices in a separate cabinet of drawers. ICs I tend to keep in a box, although the smaller and more common devices will end up in drawers as well.
Generally I keep the SMT components IN the plastic DigiKey or Mouser sleeves (the ones with the DigiKey labels on them.) Helps me with two problems: losing small parts and re-ordering. Also, if a drawer spills, it's easy to clean up, and it's impossible to mistakenly file the part in the wrong drawer. (I also take out one drawer at a time when I'm building boards, which helps avoid mixups.)
feedback
I just love these Duratool boxes:
The horizontal dividers are removable, and the bottoms are curved so it's easy to pull out small components; they don't get stuck in corners.
They are cheap too! 10 boxes for £14 and I couldn't be happier. Messing around with the breadboard is now more fun than ever before:
They do have some of the most difficult to peel stickers right across the front though...
feedback
For small components I recommend these mini storage boxes. The resistors, diodes, LEDs are easily fit in it. The best advantage of this versus a divided box with one lid, that it opens invidually. It is very useful when you accidentally knock off the box from your table... alt text
It looks something of a bother to have individual boxes in contrast to a divided box, but then that's a good point about spillage. I once had a cat run into the room and leap on the table, causing 100s of resistors to go flying all over. – DarenW Dec 4 '10 at 18:47
feedback
For passives (resistors/caps) I use little coin envelopes, one value per envelope, with the envelopes kept in a shoebox that's subdivided so they can stay upright and in order. I segregate by types, of course.
I previously used a hole punch to put a hole in each envelope, and then strung them on a keyring, but as the number of values increased, that got a bit unwieldy.
For ICs and the like, I have so few hanging around that I just keep them in little ESD bags in a box. With so few to look through it's not worth better organizing yet.
feedback
Last time I bought a resistor assortment from Farnell (61 values x 100 pieces each) I bought them with a cabinet with 60 drawers. The cabinet was virtually for free, compared to the cost for 6100 resistors.
For SMD I find Licefa V11-3 boxes extremely handy.
Each of the 60 phials (about 1cm x 1cm x 2.5cm) can contain tens of 0603 or SOT23 parts, and because you take the phial out of the box when you need a component they don't get mixed up. Very important for MLLC capacitors, since they don't have a marking.
Box exists in 60 or 130 phial versions.
My only issue is that the phials aren't anti-static.
Ow, painful: 60 drawers for 61 values! :-) – Federico Russo Jul 16 '11 at 11:02
@Federico - yes, the 61 values are 10\$\Omega\$ to 1M\$\Omega\$ in E12, but 61 is prime, so not the ideal number for a cabinet :-( – stevenvh Jul 16 '11 at 11:10
feedback
This is a useful ref. ( and links back to here ) http://opencircuits.com/Component_and_Parts_Storage
feedback
or
required, but never shown
