I have a car console that i wanna test on my work bench. It's rated at 10A DC max @ 12v, but I don't plan on driving any speakers, so the draw should remain fairly low. My power supply can only provide 3A DC @ 12 volts. If the console DOES exceed the 3A draw, will it just not function properly, or could i stand a chance of damaging my power supply
It depends on the power supply. Some have protection against overcurrent, and some don't - it should advise in the manual/datasheet (if it has one). EDIT - so it's "a charger from some old gadget". However, if you are not running any speakers from the amp, I rather doubt you will use 3 amps. Depending on the amp type (class A, AB, etc) it may draw very little current when not loaded. This info may be (should be) available in the manual. |
Depends on the design quality of your power supply. In the unlikely case of no overcurrent protection it will get hot and after a short time components will start to fail in a cascading way, so that seconds after the first one fails the whole power supply is gone. If it has common current limiting the output voltage will remain at 12 V until 3 A is reached. From then on current will not increase, the regulator will decrease output voltage to avoid a further current increase. In the event when the output voltage drops to 0 V the power supply has to dissipate a lot of power, but it should be designed to do so for some time. The input will probably be at least 15 V, then the dissipation may go to 15 V x 3 A = 45 W.
A more advanced power supply will use foldback current limiting, which solves the dissipation problem. When there's overcurrent it won't just keep on pouring out 3 A, but will decrease both voltage and current, so that internal dissipation remains limited. Normally a power supply cannot recover itself from a foldback current limit, and needs to be reset. Usually it will have a button for that, so you won't have to switch it off and on again. |
Your bench supply may get hot and electro. caps degrade quickly and have must shorter lives. If exceeded they can fail. Consider using a small SLA or lead acid in parallel to charge and operate the surges. As long as battery charge V = 14.2 max, it will operate like a car. |
