Tell me more ×
I have max four outputs coming from a PIC. I need these four outputs (or one serially) to simultaneously control 16 pins with a logic level. This is for a clock application.
A BCD could accomplish this but I don't believe it is the correct way and no one stocks them.
A set of latches could do this, but that would require me to individually latch each bit and reset when I need to switch the output.
A demux could accomplish this, if one existed that would allow multiple output pins to be high at the same time. Serial to parallel demuxers looked perfect, but all I have found only permit one pin being high at a time.
I'm looking for some type of IC.
share|improve this question
This is just to link a couple of similar threads. This one and this one. – Nick Alexeev Aug 26 '12 at 21:34
1 Answer
up vote 10 down vote accepted
The easiest way is to use one 16 bit shift register (or two 8 bit shift registers connected together). That would require only 3 pins.
  • Data
  • Clock
  • Output latch
You would need a 16 bit variable where you set or clear the bits, then you shift the data through the shift register, and then activate the output latch.
You can use two 74HCT595
share|improve this answer
Hm Ok. I initially thought that but did not think it through enough. Clearing the bits in between each set rather than shifting sounds perfect. Thank you Bruno. – Mike Jul 16 '12 at 22:55
@Mike I'm glad I helped. – Bruno Ferreira Jul 16 '12 at 22:59
@Bruno - That was too easy! I don't think you deserve an upvote for this :-). (I did upvote, of course) – stevenvh Jul 17 '12 at 17:09
@stevenvh Thanks. All my problems should be as easy as this. :-) – Bruno Ferreira Jul 17 '12 at 18:37
discard
