Tell me more ×
I'm looking at buying an AEM10010 magnetic door lock (see page 4 of datasheet), but can't figure out how they're driven. The datasheet doesn't say anything about how to connect them, nor does it provide any in-depth technical specs.
I can only assume they have two wires, one for ground and one for +ve, and I just hook them up to a 12V or 24V DC supply. Is this correct?
share|improve this question
Sometimes you can still quite easily open the door by wiggling it, make the door resonate and the magnet just won't hold the force. I remember a bridge was built once in America to just prove how resonation works in mechanical structures. youtube.com/watch?v=j-zczJXSxnw – jippie Jul 19 '12 at 9:10
@jippie I'm aware it's not infallible - it's an internal door with a mechanical lock for extra out-of-hours security. The magnetic lock is just to provide access control. Someone wiggling a door around or firing a subwoofer at it with the aim of getting it to resonate would look (or sound) mighty suspicious! – Polynomial Jul 19 '12 at 9:13
I'm actually hooking this up to a fingerprint reader, which promises to be a pretty fun project. The reader is plugged into a computer, which is connected to an Arduino via USB. The fingerprint reader triggers an authentication event on the computer, which is picked up by some code and verified in the user database. If access is granted, it tells the Arduino to unlock the door. I'm using a reed switch to check when the door is open / closed. – Polynomial Jul 19 '12 at 9:20
up vote 3 down vote accepted
As far as I can tell from the datasheet they are simply elecktromagnets, you hook 'm up to their specified DC voltage and they will hold. Remove the voltage, and they will release their hold. No latching or moving parts.
share|improve this answer
That's what I figured. It'd be nice if they mentioned it in their spec! – Polynomial Jul 19 '12 at 8:52
Known in the industry as 'maglocks' as opposed to 'electric strikes'. – MikeJ-UK Jul 19 '12 at 9:39
Based on the brief spec and it being identical in appearance to others I've met, it's a simple coil energised to hold the plate against the electromagnet.
It releases when current is broken. As noted in the data sheet, holding force is 1200 pounds at rated current. This will be approximately proportional to current so you can get eg ~600 pounds hold at half voltage.
Note that there are 12V and 24V versions of the AEM10010.
Do not apply 24V to the 12V version :-)
While some electromagnets may state currents for either 12V or 24V on the same coil it is clear that this is not what they mean here as the 24V current at 250 mA is half the 12V current of 500 mA. ie constant 6 Watts. Turns on the 12V version will be double so that the Amp-turns is the same in both cases.
Brute force intrusion detection: For extra points weaken the current to the point where you can force the door against the magnet by using ultra-violence. THEN when the door opens without the magnet being turned off declare an intrusion :-). (Intrusion detection in this way is standard).
Anti brute force latch: If you want to foil the brute force intruder you can have a simple secondary "door stop" which when deactivated stops the door if it opens say 20mm but it can be attracted away from the door by an electromagnet. This effectively serves the role of a traditional "door chain".
In a case of a power failure or brute force impact the door can be opened BUT stops after say 20mm on the secondary latch. Because this usually never touches the door in normal use it can be simple and need not have tight tolerances.
This does mean you cannot get through the door in an emergency with power off, as is the case with the magnetic plate latch alone. This may be useful or dangerous depending on your circumstances.
Wiring cut/short tamper detection: For still more points, as it were, include a series resistor R1 in the reed switch housing and a parallel resistor R2 across the reed switch, with their presence not being visibly obvious. Then, when the reed switch is not operated you see R1 + R2 and when it is obvious you see R1. BUT if you cut the wire you see O/C and if you short the wires you see S/C so you know in both cases that there is tampering occurring.
Honeypot: More points: Make the reed switch wiring run visible at some point so people may try and tamper.
And more: Make wiring that appears to be reed switch wiring visible with a tamper detector so tampering is detected but it cannot affect the actual circuit.
Thanks for the info. I was planning on doing brute-force intrusion detection already, so I could sound an alarm and log the entry time. All the wiring is on the inside of the room, so tampering and decoys aren't really a concern. Wish I could accept both answers! – Polynomial Jul 19 '12 at 10:13
discard
