I am working on a student project and need to find AVR microcontroller that will suit all project requirements. Here's a simple list:
- serial communication (UART),
- at least two ADC channels,
- PDIP package (for easy soldering, I do not have access to expensive equipment nor do I have skills to perform small-scale soldering),
- four I/O ports (excluding UART connections).
I searched on Atmel's website and was stunned when I realised that no device exists that can support these simple requirements.
Here are two devices I considered:
- ATtiny2313 (does not have ADC)
- ATtiny44 (does not support UART)
I hope that someone will be able to point me to the right device, as I failed to find one to match the requirements. Any recommendations will be much appreciated.
EDIT:
I've noticed that the device selection tool on Atmel's website is not much reliable, at least not in my case. If you list all 8-bit microcontrollers, remove all filters and filter by number of ADC channels (select at least one) and number of UARTs (select at least one), no device in a PDIP package (according to the selection in Packages filter) will be available. You can see the results here.
