Tell me more ×
I've read an appnote from TI (slaa338) that describes a technique for generating "for real" (as opposed to "pseudo") random numbers. It exploits the somewhat exotic clock subsystem of the MSP430 to achieve this goal. Does anyone know of a technique that can be implemented on an AVR (I'm interested in the XMega's in particular) for generating "for real" random numbers?
share|improve this question
psuedo random works for dice games. I think he wants cryptographically secure. – Kortuk Jul 21 '10 at 19:19
Can you give a hint as to the application and/or the degree of randomness that you require? If it's for cryptography, there are additional considerations besides just the seed quality. Some of the suggestions already made-- like sampling environmental inputs of various types may or may not be appropriate based on your requirements. – Windell Oskay Jul 22 '10 at 6:08
up vote 5 down vote accepted
How bad do you to use the XMega? If the crypto and random number generation are a big part of your project, Atmel's SecureAVR series has a hardware random number built in, and is designed for cryptographic applications.
Regardless, I doubt that you'll find a random seed source that has a good distribution. You'll want to run it through a pseudo random number generator a few times As long as you start with a different seed every time, this will give you a nice set of random numbers. An LGC is a quick and easy pseudo random generator:
static unsigned long Seed;
/* Call before first use of NextVal */
unsigned long InitSeed()
   //Your code for random seed here
   // Correct distribution errors in seed
   NextVal();
   NextVal();
   NextVal();
   return NextVal();
 /* Linear Congruential Generator
  * Constants from
  * "Numerical Recipes in C"
  * by way of
   * <http://en.wikipedia.org/wiki/Linear_congruential_generator#LCGs_in_common_use>
   * Note: Secure implementations may want to get uncommon/new LCG values
unsigned long NextVal()
  Seed=Seed*1664525L+1013904223L;
  return Seed;
share|improve this answer
Thatis awesome, I didn't realize the SecureAVR line existed, thanks for the pointer! – vicatcu Jul 22 '10 at 15:12
BTW: If you REALLY need security, the simple, effective, and fast LCG method I presented isn't what you want: Many LCGs can be broken; just get 2-3 values in a row, and plug them into an LCG generator with a set of known constants - this would include everything on the Wikipedia page. A matching pattern will let the attacker predict what the next number will be. It's possible (but harder) to figure out what the constants are from nothing, as well. – Kevin Vermeer Jul 22 '10 at 15:41
@reemrevnivek FYI, Atmel is selling off their SecureAVR line... they recommend their ARM-based 32-bit processors if you want cryptographic stuff which is a whole different ballgame in terms of development environment from AVR. They do have a couple with True RNGs on them though, maybe I'll play with them some day. – vicatcu Aug 5 '10 at 21:24
Connect up the ADC to a hardware noise source and use software to "whiten" the random numbers as needed.
Here's an AVR based project that does this: Leon's Mini Portable Random Number Generator (mPRNG)
Depending on how cryptographically secure it needs to be, you could use the noise of a floating analog input or the "internal temperature sensor" as your randomness seed instead of external hardware.
Naming a (more or less true) RNG, "-PRNG" is unfortunate. – Nick T Dec 2 '10 at 0:54
Another trick for generating a random seed, is to count the number of clock cycles until an external event. For example if this is a device to be used by a person, count the number of clock cycles until he presses the 'go' button, and use that as the random seed.
This may not be very secure against side channel attacks as they can break in by securing control of one device, but as with all cryptography, application determines feasibility. – Kortuk Jul 21 '10 at 19:20
To be sure to not restart with the same sequence, I use somme byte in the eeprom :
#include <avr/eeprom.h>
#include <stdlib.h> // rand
u16  EEMEM randinit;
int main(void) {
        srand(eeprom_read_word(&randinit));
        eeprom_write_word(&randinit,rand());
This give quite good random, and does not cost much in programme/memory.
This reads byte 0 every time. What evidence do you have that this byte is random? If it is, this is a great technique! – Kevin Vermeer Jul 23 '10 at 1:19
This word (byte 0 & 1 in fact) will be random, because at each startup I initialise the random generator with it's content. THEN I upload it with a new rand(). So the next init will look random from the current one... and so on... But if I reset randinit to ffff (or 0000?), I will have the same randinit sequence! So it's not perfect. I forgot a warning about the fuse who erase the eeprom when uploading the *.hex ;) – jojo l'abricot Jul 23 '10 at 19:57
Have you looked at using something like randomSeed()? - used in the Arduino IDE
You can use this function to sample a floating (free) analog pin on the atmel AVR, it then uses the value to create an arbitrary starting point for the pseudo random number function - random().
The value created by random() may be a pseudo random number - but the arbitrary starting point created by randomSeed() should be as real a random number/value as you can get.
Sampling things like the analog pins is close to random, but will not have an even distribution. Run the seed through random a couple times, however, and it will. – Kevin Vermeer Jul 22 '10 at 3:34
....through a pseudo random number generator a couple... <- How did that go missing? NTS: Engage brain first, then fingers. – Kevin Vermeer Jul 22 '10 at 10:06
Exactly - It's also not the most secure if using it for encryption / protection etc, but it will give you a nice random number for something like generative music or dice games. It's good and easy to implement too :) – Jim Jul 22 '10 at 10:17
discard
