I have an LCD screen which expects power from a 5V line, but I want to hook it up to my Raspberry Pi's GPIO pins which only supply 3.3V. What equipment do I need to increase the voltage from 3.3V to 5V?
If you only need to send data to the LCD you can use HCT buffers. HCT is TTL-compatible HCMOS, so made to work at 5V, but instead of needing 0.6 Vcc input for a high level (or even 0.7 Vcc) it can do with TTL levels, i.e. 2.4 V for a high level. The 74HCT241 is an octal buffer. For status and other unidirectional lines from the LCD you can use a resistor divider to scale the 5 V down to 3.3 V. A 10 kΩ resistor in series with a 20 kΩ gives you 3.3 V out for 5 V in. |
If you want to interface 5V and 3.3V logic you will need a level shifter. Maxim has a good app note on this here: http://www.maxim-ic.com/app-notes/index.mvp/id/3007 For I/O lines make sure your chosen level shifter is bi-directional. You will not be able to power your 5V LCD from the 3.3V Raspberry Pi without something like a boost converter, or use a separate power supply.
Since you are looking to power it, the GPIO pins are current limited. You would be better off using a single 5 V power supply to power both the Rasberry Pi and the LCD. It would need to supply the current to the Rasberry Pi (700 mA), plus however much the LCD needs. |
