Recently my old amplifier in car has got a defective contact on one of the switches, so I decided to unsolder the old one and solder a new one. Unfortunately the amplifier caused a short as I connected it to the battery again (I don't know how this could happen, maybe I damaged some component or something, or maybe there was suddendly a wrong connection due to soldering althought I don't think so).
What I've done next is to unsolder the switcher again and bypassed the needed conducting paths by soldering some kind of bridge (I don't need to switch it again, it's ok for me when it just works with a specific adjustment). But before I try to connect it to the battery again, I'd like to test if this is save. So I thought about using an ohmmeter. My idea is when I connect it to the plus pin and minus pin of the amplifier, the resistance must not be 0 Ohm, because this would cause a short since 12V / 0 Ohm means infinite current. Are my thoughts correct? Or do I miss something important?
The Ohmmeter will do fine, you are correct in thinking there should not be 0 Ohms (read very low resistance e.g. <10 Ohms or so) between the amplifier power leads. |
While I am not sure exactly what you have done (pictures or a schematic would be helpful) I do know that you can measure if two wires are connected by using the method you described. However, the best way to check this is with a continuity checker. If the ohmmeter you bought can also measure other things, I would read the instructions to see if it can also measure continuity. If you live near a harbor freight, they sell multimeters with this option for about 5 bucks. They also sell continuity checkers for a little less. If you plan on doing electronics much in the future I would definitely invest in a multimeter with a continuity checker. They are nice because you just place the probes on the two nodes you are interested in and it will audibly beep if the two nodes are connected. Hope this helps! |
