From looking at datasheets for inexpensive Op-Amps like the TI TL082 or ST MC1458, how do I determine the performance near the supply rails?
Is it the "Maximum peak output voltage swing" minus the supply voltage? For example, the specs indicate TL082 VOM = ±12 V, VCC = ±15 V, so the output won't get within 3 V of either rail (with an RL of 10 kΩ)? TI dedicates 6 figures to characterizing that parameter (especially over supply voltage), so I assume so, but ST leaves me shortchanged (c'est la vie?).
They seem to suggest that it's "symmetric", or the same near each rail, which I wouldn't expect. Is that just ignored for the sake of brevity and the worst-case (approaching the high rail) assumed for the low?
