Tell me more ×
I'd like to measure the frequency response of my power amplifier, while it is connected to a loudspeaker.
The power amplifier outputs at +- 50V, and I think the maximum input of the sound card is approximately 1.5V. The input impedance of the sound card is 1 K ohm or 1 M ohm (there is switch to select the impedance).
I think the first step is creating a voltage divider, and match the impedance with the input impedance of the sound card. The next step is -- since I can't afford replacing sound cards for every mistake I make -- is add some zener diode protection.
Is there anything I'm missing, or any other protection I should add. The circuit I've got so far:
share|improve this question
up vote 5 down vote accepted
Don't bother.
Unless your power amplifier is an "audiophile" amp, or older than 20 years, or is damaged in some way, or built by yourself then the frequency response is flat. Ok, not perfectly flat but flat enough. There will be some low frequency rolloff below 20 or 30 Hz. If it's a class-D amp then there might be some rolloff above 18-20 KHz. But for 99.9% of the people and 99% of all speakers this rolloff is insignificant.
You are also assuming that your sound card has a flat frequency response. But sound cards, particularly cheap sound cards, have terrible input performance. They all have low-frequency rolloff, but a cheap sound card might have the rolloff start as high as 100 Hz. This is actually ideal if you are connecting a microphone, but not so good for music. I would be surprised if a good sound card wasn't flat from 100 Hz to 20 KHz, however.
Also, you don't want to measure the response when connected to your speaker. You should do it when connected to an 8 ohm or 4 ohm resistive load. This will eliminate any weirdness that the speaker itself could give.
So, using your sound card to measure your amps frequency response is unlikely to tell you anything useful (since you cannot differentiate between the amp or the sound card).
But let's say that you have one of those weird amps that is almost guaranteed to have worse frequency response than your sound card (tube amps, DIY amps, broken amps, etc.). In that case the schematics you gave will not work very well.
The first problem is with the amp output. Those schematics assumes that one of the speaker terminals is ground, while the other is driven by the amp. This is not always true. Some amps drive both the + and - speaker terminals and you can't always tell by just looking at the amp. If you use this circuit with that kind of amp you can damage things.
The second problem is that the zener diodes should not be in parallel. Instead put them in series (but back to back). Otherwise one zener will always be conducting even when the audio level is not too high.
The third problem is if the amp is a Class-D amp then it might be spitting out a lot of high-frequency noise (>20 KHz) that could confuse cheaper sound cards. You would need a low-pass filter to remove that noise so it does not effect your measurements. Note: This filter is actually a lot harder to make than it sounds.
Otherwise, the circuit will work provided that one of the speaker outputs is actually connected to ground. But you must use great care to verify that before using this circuit.
Most amps will not work with this circuit, however, either because of the ground problem or the high frequency noise.
Because of the difficulty in making accurate measurements, the risk of doing something bad, and the limited usefulness of doing it on modern amps, I would not bother doing it. If I had to, then I would buy some gear that is designed for this. I actually have a system from Audio Precision that is designed for this (and a bunch more), but these are super expensive. Cheaper products are available but you are still talking about spending several thousand US dollars.
share|improve this answer
Thanks for the response, its a Class AB amplifier. I've checked the frequency response of my sound card, and it goes down to approximately 10 Hz. I'd like to deconvolve the amplifier response from the measured response - if I use a purely resistive load, it won't be the same as when a speaker is connected. From the schematics of the amp, it looks like the amp is driving the positive terminal, while the negative is connected to ground. I'll double check everything before connecting up. Thanks for the advice – Busk Aug 12 '12 at 17:50
You think the maximum input is 1.5 V. In that case the placement of D1 and D2 is a good idea, though technically it's wrong :-). D1 will clip positive voltages at 3.3 V which is higher than the 1.5 V. But D2 is then forward biased, and will drop 0.8 V, so that will decide the clipping level. The same thing goes for negative voltages, there D1 clips at 0.8 V. You're not using them as zeners, so 1N4148s will do as well.
I would set the input impedance to 1 MΩ, then you don't have to look after it anymore.
Then there's the R1/R2 divider. If you want to scale 50 V down to 1.5 V (or 0.8 V, clipping) then the divider ratio should be 33:1, so use a 33 kΩ for R1, the 1 kΩ for R2 is then OK.
Note: I'm not sure the measurement will be very useful. Amplifiers have a much flatter frequency response than speakers. If you're interested in the performance of your system you should actually measure the speakers' output, preferably with a measurement microphone, otherwise the microphone's response curve will distort the measurement. Measurement microphones are pretty expensive, but you can often rent them for a day.
Thanks for the response; I was measuring the amplifier response so that I can deconvolve it's response from the speaker response I'm measuring separately. I was just ensuring that the ideas were correct, I'll double check the values and specifications of everything before I build the system. Would adding another i.imgur.com/SRXuX.png – Busk Aug 12 '12 at 16:54
@Busk - what are D3 and D4 connected to? Is that also ground? In that case they serve no function, as D4 is just a double of D1 and D3 a double of D2. – stevenvh Aug 12 '12 at 17:06
discard
