My employer sells boost converters to hold up motor drives during power loss. These boost converters are fed from capacitor banks. In order to size these banks correctly, we need to take their voltage, capacitance, and ESR into account, to ensure that there is enough available energy from the capacitors to hold up the drives for a spec'd time at a spec'd power. Right now we do this with an approximation method, but it would be nice to have a more exact equation.
We're assuming ESR, capacitance, and load power are constant.
$$ I \text{: current}\\ P \text{: power}\\ R_{C} \text{: ESR}\\ C \text{: capacitance}\\ t \text{: time}\\ V \text{: capacitor voltage}\\ \text{Standard capacitor equation:}\\I(t)=CV'(t)\\ \text{Power out of the cap equals power into the ESR plus power into the load:}\\ V(t)I(t) = P + R_{C}I^{2}(t)\\ \text{Substitute:}\\ CV(t)V'(t) = P + R_{C}C^{2}(V'(t))^{2}\\ $$
If I'm right, this gives me a non-linear differential equation, which puts me well past my mathematical comfort zone. If I understand correctly, solving a new non-linear differential equation would qualify as a significant contribution to the field of mathematical knowledge. Given that, I'm unlikely to solve this on my own.
Does anyone know any good approaches for solving for V(t)? Does anyone know if this equation has already been solved? Am I possibly misunderstanding the problem? Or should I move this to the math Stack Exchange?
Z_L, though I think you should be able to figure it out by back-calculating from what power rating and acceptable voltage drop you expect your design to have. – helloworld922 Aug 16 '12 at 17:21
