I am using the the Atmega328 (not the Atmega328P that is standard with Arduino) on a breadboard version of the Arduino. I am able to get the bootloader on the Atmega328 using these instructions. In summary, you add a new entry for the 328 to the avrdude.conf file and the boards.txt file.
Then, I am able to get my program on the chip by going to Tools>Board and setting it to Arduino Uno w/ ATmega328 (non-P) then burning the bootloader on the chip using the 328 config files with the AVR Pocket Programmer. Then I go to Tools>Board and switch it to Arduino Uno and upload the program using the normal USB connection.
Now, my question is about using the File>Upload Using Programmer functionality. When I do this for the the Atmega328p on a fresh chip everything works. However, when I try it for the Atmega328, with the IDE set to upload to Arduino Uno it throws the error:
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
Double check chip, or use -F to override this check.`
Is there another config file that has to be changed to enable the "Upload Using Programmer" functionality on other chips? If anyone has some tips on where to look it would be greatly appreciated!
Edit1:
I also tried setting the IDE to Arduino Uno w/ ATmega328 (non-P) and it throws this error:
unknown MCU 'atmega328' specified
Known MCU names:
avr2
at90s2313
at90s2323
at90s2333
at90s2343
attiny22
attiny26
at90s4414
at90s4433
at90s4434
at90s8515
at90c8534
at90s8535
avr25
attiny13
attiny13a
attiny2313
attiny24
attiny44
attiny84
attiny25
attiny45
attiny85
attiny261
attiny461
attiny861
attiny43u
attiny48
attiny88
at86rf401
avr3
at43usb320
at43usb355
at76c711
avr31
atmega103
avr35
at90usb82
at90usb162
attiny167
avr4
atmega8
atmega48
atmega48p
atmega88
atmega88p
atmega8515
atmega8535
atmega8hva
at90pwm1
at90pwm2
at90pwm2b
at90pwm3
at90pwm3b
avr5
atmega16
atmega161
atmega162
atmega163
atmega164p
atmega165
atmega165p
atmega168
atmega168p
atmega169
atmega169p
atmega32
atmega323
atmega324p
atmega325
atmega325p
atmega3250
atmega3250p
atmega328p
atmega329
atmega329p
atmega3290
atmega3290p
atmega406
atmega64
atmega640
atmega644
atmega644p
atmega645
atmega6450
atmega649
atmega6490
atmega16hva
at90can32
at90can64
at90pwm216
at90pwm316
atmega32m1
atmega32c1
atmega32u4
atmega32u6
at90usb646
at90usb647
at94k
avr51
atmega128
atmega1280
atmega1281
atmega1284p
at90can128
at90usb1286
at90usb1287
avr6
atmega2560
atmega2561
avrxmega4
atxmega64a3
avrxmega5
atxmega64a1
avrxmega6
atxmega128a3
atxmega256a3
atxmega256a3b
avrxmega7
atxmega128a1
avr1
at90s1200
attiny11
attiny12
attiny15
attiny28
Blink:-1: error: MCU 'atmega328' supported for assembler only
Edit2: Here is another person with the same problem but without an answer.
