I have a 2 MHz SPI bus but one thing I've noticed that is that some of my signals often 'shiver'. Yes my trigger is setup properly so I don't think the issue lies there.
You can see what I mean here: (this is with persistence mode on). This is the clock of my SPI bus.
The SPI does work fine. I've transferred hundreds of megabytes on multiple boards and haven't seen an issue so far. But I'm still interested in knowing what could be the issue here. Also, should I bother fixing it even it works?
The measurements were taken right at the source with a VERY small ground clip.
This is a simplified schematic of my circuit. Of course the board has more SPI devices but for the purposes of this question this is accurate because the board has nothing soldered onto it yet except the uC and the SD Card.
The master (AVR Mega 128) is running off it's internal RC oscillator - I don't know if this would be relevant but since the signals shift in time it's possible that the RC oscillator's jitter is also ending up in the SPI bus. Just thought I'd mention it. It also occured to me that during these measurements I ran the controller in an infinite loop. Here's the code:
while(1)
setFirstBitOnDriver(driver); // this sends a 8-bit command on the SPI bus.
GLCD_SetCursorAddress(40); // Change cursor position on the display.
GLCD_WriteText("LED: ");
for(wire=0;wire<72;wire++)
itoa(wire+1,str,10);
GLCD_WriteText(str);
GLCD_SetCursorAddress(44);
_delay_ms(10);
shiftVectorOnDriver(driver); // another command on SPI. 8-bit wide.
The jitter/shiver could happen when the internal runs for 72 times and then exits. Since it takes an additional time to execute the first three lines it could be that every 73rd waveform arrives at a slightly different time due to the additional processing time. If I had to bet, I'm guessing this is the cause of my issue (if I could, I'd confirm it this instant but my boards at work and the next week is off!) But I'd still like opinions/answers of SE on this matter.
But considering the uC is running at 8 Mhz I don't jitter due to software would be because in nanoseconds but rather microseconds. But in the 2nd figure a flat line is visible. This occures for a very brief second where the entire waveforms shifts in time and is invisible on the screen. I'm guessing that this is due to the loop and the jitter in the first picture is due to the RC oscillator.
