Tell me more ×
So I'm looking into buying a portable fan, most I've looked at run on D batteries (8) aka 12V. Now I don't feel like buying 8 D batteries every time I want to run this thing and I can't find rechargeable Ds (im sure they would be expensive). I was thinking however, I do have number of 18v drill batteries, is it feasible to fun the fan on off of those?
share|improve this question
Which fan, which batteries exactly? That's important so we can give you a relevant answer. – AndrejaKo Aug 22 '12 at 13:59
Someone told me that D-type and the other similar batteries are some of the lowest cost for available power batteries that you can get. Even some packaged batteries, maybe your drill, are just repackaged D or similar. – kenny Aug 22 '12 at 14:03
The battery is a Dewalt 18v drill battery, the fan is an O2-Cool 10" fan that takes 8D's ... is that enough info? – user379468 Aug 22 '12 at 14:17
1 Answer
up vote 2 down vote accepted
Yes. You just need to lower the voltage to 12V. A simple PWM circuit is all that you need. Something like this: enter image description here
From http://www.dprg.org/tutorials/2005-11a/index.html
share|improve this answer
excuse my noob question, but I may actually also have a crappy 12V drill, in theory would that work? do you have to also match the amperage? or is that just something with wall current – user379468 Aug 22 '12 at 14:21
@user379468 With a 12V battery, You'll have no problems (just be sure to match the polarity between motor and fan). Current is not an issue: if it works with 12V from D cells, it will works with 12V from a NiCd/NiMh/Li cordless drill battery pack. – Axeman Aug 22 '12 at 14:26
Might be worth mentioning that the peak voltage will still be 18V (in case someone tries to use this circuit for something other than a simple load) and also the duty cycle will need to be set to (12/18) * 100 = 66%. Maybe add a fixed resistor to make it able to vary from 0% to 66% (rather than up to 100%) – Oli Glaser Aug 22 '12 at 16:23
discard
