I am working on a firmware project in which i have to do a crc16 check for flash integrity.
Controller: MSP430 IDE: IAR EW 5.40 (Linker Xlink)
The crc is calculated using IAR Xlink linker and kept at the end of the flash. Again crc is calculated at run time from the code and compared with the stored value in the flash to check integrity. However, we can only calculate crc on the code segment of the flash memory. It's size may change whenever we make some changes in the code. Can i automate this process which i am manually doing right now?
from the .xcl linker file:
// CRC16 Essentials: -H for fill,-J for checksum calculation
-HFF
-J2,crc16,,,CHECKSUM2,2=(CODE)5C00-FF7F;(CODE)10000-0x20A13
Here i need to change the end value of second code segment which is 0x20A13 right now. I get this value from the .map file, i.e on how much memory range my code is residing inside the flash. This is the 1st change i make.
Here i need to make 2nd change from code:
sum = fast_crc16(sum, 0x5C00, 0xFF7F-0x5C00+1);
sum = fast_crc16(sum, 0x10000,0x20A13-0x10000+1);
//Check the crc16 values
if(sum != __checksum)
// Action to be taken if checksum doesn't match
Please help automating this process!!
