Tell me more ×
I'm developing a driver for multiple USB speeds and according to the universal specification, I'm allowed to draw a greater amount of current from a USB 3.0 hub than the other versions.
Is there a way on Windows to determine the different USB speeds? I'm basically asking for a place to get started. Thanks in advance.
share|improve this question
Please clarify your question further. "The different USB speeds" of what? Do you want to determine the data-transfer speeds of the various USB ports on a given computer? – boardbite Aug 24 '12 at 20:13
I want to clarify regarding USB normal/full/high/super speeds (mentioned in the specification) – Yasuko Dino Aug 24 '12 at 20:16
For more info, you can check for normal/full speeds using the power settings of the USB hubs/devices – Daniel Li Aug 29 '12 at 15:30
1 Answer
up vote 5 down vote accepted
Since you're using Windows, you should look into using Windows Driver Frameworks (WDF). This is the Windows equivalent to libusb on POSIX-compliant computers.
WDF Reference
Look through the example code (there's a toaster/firefly driver example in there) on how to set up a WDFIOTARGET given a device ID. Use this implementation with your hub, enumerating it upon device insertion.
Then, you'll want to send the IOCTL, IOCTL_USB_GET_NODE_INFORMATION, to the hub represented by a WDFIOTARGET in order to retrieve a USB_NODE_INFORMATION structure.
IOCTL Reference
USB_NODE_INFORMATION Reference
Then, retrieve with the following access pattern:
PUSB_NODE_INFORMATION UsbNodeInfo = NULL;
// retrieve UsbNodeInfo here with your USB_GET_NODE_INFORMATION signal
UCHAR DescriptorType;
DescriptorType = UsbNodeInfo->u.HubInformation.HubDescriptor.bDescriptorType
HubInformation Reference
HubDescriptor Reference
This will retrieve a descriptor type of either 0x2A (3.0) or 0x29 (2.0 or lower). Using this information, you can send the proper IOCTL you want to the device in order to demand a greater amount of current from the hub like so:
if (DescriptorType == 0x2A) {
    // handle USB 3.0 current specification here
} else {
    // handle USB 2.0 current specification here
Hopefully this is enough for you to get started. Enjoy!
share|improve this answer
discard
