I'm looking for low profile board-to-board connectors with 2.54mm pitch that compatible with usual 2.54mm, and has smd and through hole versions
Tell me more
Electrical Engineering Stack Exchange is a question and answer site for
electronics and electrical engineering professionals, students, and enthusiasts. It's 100% free, no registration required.
closed as off topic by Brian Carlton, Olin Lathrop, Leon Heller, embedded.kyle, Connor Wolf Nov 2 '12 at 8:28
Questions on Electrical Engineering Stack Exchange are expected to relate to electronics design within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
Shopping questions are generally off topic, but it happens I recently required a low profile board to board connector. I found these from Samtec, so I thought I should mention them: BBL Series Headers I don't think they do any in surface mount, but these are by far the lowest profile I found (as low as 3.89mm) and 2.54mm spacing. Farnell stock them. |
