First, fix your switching compoments as Steven has recommended. The boost diode needs to be ultrafast, preferably with soft recovery characteristics.
I would also connect the SD pin to ground instead of leaving it floating, to prevent spurious shutdowns of the IC.
Second, check your reference voltage. \$ V_R \$ with respect to GND should be 5V, and \$V_{NI}\$ will obviously be half of that if you're following Figure 8.
Third, check that your feedback divider (\$R_F\$ and the \$5k\Omega\$ resistor going to \$V_{INV}\$) are sized to give you \$V_{NI}\$ when the output is 10V.
Next, using a scope, check that your desired switching frequency can been seen at \$C_T\$ or at OSC.
Next, see if there's any duty cycle being generated at CB.
