My Xbox 360 won't power on. I cracked open the case (beyond warranty) and started testing voltage points with a multimeter. No point was registering anything. So I tested the power supply, and it only registered 5V, but it should be 12V.
To narrow down the problem, and be sure, would the power supply start supplying the full 12V only when plugged into a working Xbox (like a failsafe)?
