What actually is an Atari SIO connector, if I wanted to order the part? I have tried Farnell for DB13, Dsub 13 etc but no joy. I am assembling a SIO2ST for an 800XL.
I'm the owner of the site you linked to (SIO2ST schematic http://mixinc.net/atari/pinouts/stxl.htm ). This connector is indeed a proprietary one, only used on the Atari 8-Bit line of computers (400/800/XL/XE). However these connectors are still available from a few sources (like BEST Electronics or B&C Computervision) many people choose to mount such an interface into the Atari itself and just connect the few wires to the internal side of the SIO chassis. You can use a DB9 chassis and make a hole exactly above the SIO chassis to fit the DB9. Wire it in a way so you can use a standard modem cable to make the connection between the Atari XL and Atari ST. |
It's proprietary. You may have some luck via Best Electronics (apologies for the gaudiness of the linked site) since they seem to have tons of old Atari inventory. |
