Tell me more ×
I am new to antenna theory, and I have been reading up on antenna properties to create my own antenna.
I want to use a piece of copper wire, maybe around 18 gauge, as a monopole antenna, but it will also be electrically short, at least less than lambda/10.
Furthermore, the antenna will be designed for a single frequency.
Other than the fact that electrically short antennas have a high input reactance, I can't find any information on how to calculate the radiation resistance of a straight, round wire without using a network analyzer. Does anybody know of any information or software I could use to calculate this radiation resistance for impedance matching? Thanks!
share|improve this question
This is beyond my own expertise, but I know that the ARRL Antenna Book (my copy is ancient) has not just a lot of theory, but also a lot of practical information on how to match impedances, check SWR, etc. arrl.org/shop/ARRL-Antenna-Book-22nd-Edition – mickeyf Sep 15 '12 at 3:32
@mickeyf Thanks, I saw that the latest edition has chapters on space limited antennas and portable antennas. – Ag565 Sep 15 '12 at 5:42
Do you have to use a monopole for this? There are much better approaches for electrically-short scenarios (all of which are basically clever ways of being less "short" in the same volume). For example, the Folded Unipole Antenna (FUA). If you only need narrow-band operation then you have lots of awesome options. What frequency (just curious)? – DrFriedParts Mar 29 at 5:51
1 Answer
a monopole antenna have a varying radiation resistance according to the ground plate size. you can use a serial coil to eat up the capacitive parts of a short monopole and you would get a pretty good match with a 50ohm receiver front-end.
share|improve this answer
discard
