Tell me more ×
I got a digital design problem. My final implementation of the circuit program didn't achieve the required criteria, so I brought my problem and my works here to be suggested by you if I mis-manipulated any details.
Logic System: Binary--1,0.
Issue after Simulation and Test on Circuit Board: LED lighted up at the begining without any switches were turned ON. (Would it make sense?)
Problem Statement:
Use 4 switches A, B, C, D to control a LED. LED is ON if the following conditions are satisfied,
D and B turn ON,
or A turns OFF while C turns ON,
or A and B turn ON and the rest turn OFF,
or C and D turn OFF,
or all switches turn ON.
End of Problem Statement.
Notations and Circuit Combinations we use:
AND gate: · (dot)
OR gate: +
"Not/Invert something": ~
SOP: Sum of Products
POS: Product of Sums
SOP and POS are equivilant to each other.
My works:
True Table based on the 5 criteria
ON:1, OFF:0.
Collection of LED results is {1011111110001101}.
I can handle operating the software part, but I really want to check with you guys if I use POS method and based on the 5 criteria given in the problem, whether or not my true table is correct.
Please help me to point out my blind spots. Thanks
share|improve this question
how about instead of a delete you removed your answer from the question and post your answer with details of how you accomplished it to help future users. – Kortuk Sep 19 '12 at 2:51
@Kortuk Then I'd spare this question's life, if you think it deserves mercy. Thanks anyway. – Joyful Sylph Sep 19 '12 at 21:16
1 Answer
up vote 2 down vote accepted
Going by the problem definition directly:
  1. D and B turn ON: B•D
  2. A turns OFF while C turns ON: ~A•C
  3. A and B turn ON and the rest turn OFF: This condition is already covered by condition 4.
  4. C and D turn OFF: ~C•~D
  5. all switches turn ON: This condition is already covered by 1.
So your final function is: B•D + ~A•C + ~C•~D
3 ands, 2 ors.
share|improve this answer
I tested my true table again without interchanging between 0&1 for the program and it was correct. It also verified your statement that the 3rd condition is irrelevant because of condition 4, and I finally understand why you concluded that. I think what messed me up previously was that I changed 1 for 0 and vice versus in my program so that absurdity occurred. Thanks. – Joyful Sylph Sep 18 '12 at 0:59
discard
