Tell me more ×
The battery in my electric razor has failed to charge for several years. It does not turn on unless I leave it plugged in for 20 minutes and it turns off immediately if I unplug it. To save some money, save the world, and have some fun... I decided to take it apart instead of throwing it away.
Inside I found a black NiMH battery without much of a description. Is it safe to replace this with any old NiMH battery with any mAh capacity? The electric razor seems to work fine with the new battery... but charging it might be an issue if it is made specifically for the built in battery. The charger says the output is 15v DC at 420mA. Is there anything I should consider in replacing this battery?
Edit:
I let the bad battery charge for an hour. It got up to 1.46 volts. After half an hour of letting it sit, its now at 1.39 volts.
I measured voltage of the batteries as they were attached and detached from the charger.
The good battery is charged to 1.41 volts and goes to 1.42 volts when attached.
The bad battery is charged at 1.39 volts and goes to 1.4 volts when attached.
I did something dangerous and discharged the bad battery with a paper clip. It's now at 1.21 volts and the voltage went to 1.33 while attached to the charger.
In any case, the voltage is in the right range for the new battery. I'm still not sure if its doing smart charging since it seems logical that the voltage difference will become less as it gets closer to the chargers voltage.
When I disconnect the battery and just measure the voltage across the battery connectors inside the razor, it measures .05 volts (while making a high pitched ringing noise). I'm guessing its doing some sort of smart charging if I haven't broken it yet.
share|improve this question
The 1.41-1.42 V end point suggests smart charging. The new battery should work well. | Discharging a NimH with eg a paper clip is not advised but in my experience does not cause major danger to life. Doing that with a LiIon battery would be exceedingly unwise and potentially health threatening. – Russell McMahon Sep 19 '12 at 17:05
@RussellMcMahon Thanks! I'll go ahead and use the new battery. I am convinced that it is doing some sort of smart charging since it charges all the way up to 1.46v and then drops down to 1.43v after the charge indicator shows that it is complete. It might not charge to full capacity but I am convinced it is safe to use. – James T Sep 19 '12 at 17:18
up vote 3 down vote accepted
I very seldom disagree with Olin technically. In this case there may be special circumstances which make part of his advice correct in general but specifically wrong in this case.
As he notes, first it is necessary to establish the voltage across the battery to ensure it is in fact a single cell and not a number in series. As you say that the razor operates OK on the new battery then it is extremely likely that the old one is also a single cell.
15 VDC at 420 mA sounds just plain wrong. The voltage is high by a factor of about ten times, so maybe it's 1.5V.
For a 2300 mAh cell the 420 mA would be C/(2300/420) ~= C/5.
This is an OK charging rate BUT if the charging is not COMPLETELY terminated when the cell is charged the cell will "cook" in short order.
For capacities up to 1500 mAh, maybe 1800 mAh NimH calls had special arrangements (chemicals and structures) which allowed recomination of Hydrogen when "gassing" occurred when a cell was left on charge when fully charged. This allowed manufcxaturers to specify a trickle-charge rate of say C/10 (230 mA for a 2300 mAh cell). At or below this rate the cell could be left on charge indefinitely with little or no damage. HOWEVER as the typical battery capacity arms-race occurred and capacities were pushed up to 2100 2300 many_lies 2500 2600 all_lies ... mAh the manufacturers looked for more space to fit active material into. Something had to go, and it was the gas recombination mechanism. Modern NimH cells above about 2000 mAh from reputable manufacturers have data sheet advice of the form:
- Do not trickle charge at all! or
Trickle charge at no more than C/20 or whatever for some_very_small_period or
Can be trickle charged at <= C/100 on a good day downhill with the wind behind you.
Any battery manufacturer whose data sheet says ... 2500 mAh ... trickle charge at <= C/10 can be safely shunned as a source of supply for all future time.
SO when Olin says " ... In that case, the highest capacity battery is best since it will be abused less at the same current." - this is good advice in the general case BUT not so when using NimH where the charger is badly behaved. In such cases use of an older style 1500 mAh cell would probably [tm] give a much longer life.
However - IF the charger really is a true 1.5V charger and if this is tightly controlled (rather than edging upwards as load current drops, then it MAY be OK.
At say C/10 the terminal voltage of a NimH cell at room temperature at the end of charge will be ~= 1.45 V. 1.4 is safer and 1.5 is a bit high. Actual value varies slightly with manufacturer. Temperature much above 25C vary this voltage BUT also are best avoided. Higher charge rate lead to higher voltage st end of charge.
SO - measure charger output. If it is 1.5V and no more your battery may last OK. If it rises to > 1.5V at light loads you MAY be able to load it down with a suitable resistor. But using a 1500 mAh cell is probably wise.
Added:
The 1.46 Volts after 4 hours sounds very good. That's 420 x 4 = 1680 mAh BUT the 1.46 volts sounds like a fully charged cell so presumably the cell was partially or filly charged originally.
Try an overnight charge - if it's still at 1.46V they seem likely to have done a reasonable job of charge control.
If you are able to measure the battery current on charge at the end of an overnight charge you will be able to tell if it is trickle charging. This can be accomplished by eg a battery interceptor / continuity break insulator against the +ve battery terminal and add a conductor on either side and take wires out to an ammeter. OR locate the battery externally and bring out two wires to it via an ammeter.
Here's an example of a battery interceptor, From here
= http://www.instructables.com/id/Remote-Power-Control-For-Battery-Powered-Devices/
share|improve this answer
Hi Russell. My multimeter measures 16.5v coming from the charger... so the 15v on the label is accurate enough. I'm confused about "C". Is it celsius, capacity in mAh, or some constant? – James T Sep 19 '12 at 0:30
C means ~~= Capacity. C is the charge rate in mA equal to the capacity in mAh = current required to charge in 1 hour if 100% efficient. For 2400 mAh cell C = 2400 mA, C/6 = 400 mA. C/10 = 2400 mA etc. – Russell McMahon Sep 19 '12 at 2:13
Can you measure the voltage at the battery terminal under charge? Especially while on charge after 4 hours charging. – Russell McMahon Sep 19 '12 at 2:14
Thanks. And yes I updated my answer with voltage while charging. I'll update it with more values after 4 hours. – James T Sep 19 '12 at 2:55
+1 since this contains more detail and background than my more quick and dirty answer. Good point about the lower capacity cells having the recombination feature, although today such cells will be about impossible to find at ordinary retail outlets. Now that we know the voltage levels off at 1.46 V even after long charging, his suggested replacement cell should be fine. It may not live as long as when extra carefully treated, but replacing this cell every two years is still a cheap and effective enough solution in the scheme of things. – Olin Lathrop Sep 19 '12 at 13:51
show 4 more comments
Let the old battery charge and then measure its voltage. If it is around 1.5 V, then a single cell like you pictures will probably work well enough as a replacement. There is a chance that the old battery had multiple cells, in which case the single cell replacement will not work correctly.
If the voltage on the old cell is about 1.5 V, then it would be good to roughly match the capacity of the old cell. However, the dumber the charger, the less this matters since it's going to abuse the battery anyway. In that case, the highest capacity battery is best since it will be abused less at the same current.
The voltage and current rating of the charger is not really relevant since there could be a circuit between it and the battery. It could simply be a current limited charger, which isn't great for the battery but happens often enough in cheap consumer products.
It sounds like this product was optimized for initial sell price and little else. That's the way a lot of consumer products are nowadays. Manufacturers don't make quality products because they cost more to purchase initially so nobody buys them, even if they would be cheaper in the long run. Of course without good information even quality-concious consumers have little to compare models with except the price, so the system perpetuates itself.
Your right about there being a circuit between the charger and the battery. Your also right about the existing battery being about 1.5V. I don't know how to match the capacity of the old cell though since it is not labeled. – James T Sep 19 '12 at 0:49
discard
