I have a Sony bluetooth earphone. It has a usb terminal, which I thought it was only for the purpose of charging power. But when I connected it to a computer, it seems like it is detected as a usb device, not just taking power from the computer. What is the purpose of it being designed to be detected as a usb device? I am planning to replace the usb terminal (mini B female) to usb A male so that I can charge power to it without cable. If I only connect V+ and V- and ignore Data+ and Data-, would I lose some function?
Tell me more
Electrical Engineering Stack Exchange is a question and answer site for
electronics and electrical engineering professionals, students, and enthusiasts. It's 100% free, no registration required.
Most likely the data connection is for firmware upgrades, since 100mA is usually more than adequate for charging purposes for a Bluetooth earpiece. If you feel confident that the device is secure and working properly then you can go ahead and leave the data lines floating. |
