I'm getting one of these http://www.old-computers.com/museum/computer.asp?st=1&c=446
I'm planning to build a server inside it. And I was thinking of using the built in CGA-monitor as a statusdisplay (LCDInfo style, or whatever the cool geeks use nowadays). The screen is monochrome amber so it would probably look a bit like the Planar EL-screens some have been using in their mods. And I want to use an Arduino (or something like it) as a middleware solution... PC -> Arduino -> Screen
I have been checking up a bit, and CGA is a RGBI signal using TTL-communications. 4 lines (RGB + Intensity), combined with HSYNC (15.75KHz) and VSYNC (60Hz). The 4 "color-inputs" are logic on or off. The combination of these generates up to 16 colors. However, as this is an amber screen, it would probably be easiest to start with "all-high" or "all-low"... White and Black.
So the problem is the following... I could probably both wire and code the arduino to flip the TTL-lines on and off, but I'm not sure what I do with the HSYNC and VSYNC inputs. And how to time the TTL-flips to correspond to pixels on the screen. (The standard CGA resolution is 320x200).
I'm not very good at electronics, but I'm very good at following instructions, and taking hints
Has anyone tried this before?
EDIT: Could I maybe use a modified version of this? http://www.eosystems.ro/deogen/deogen_en.html
EDIT2: I don't need to use an Arduino. But I want to keep it as simple as possible.
EDIT3: It might seem that the monitor in question actually is a composite monitor, and not a "real" CGA input monitor. So that probably makes things a bit easier. But I'm still interested in how to generate a pure CGA signal using a microcontroller...
