Tell me more ×
I am working on a project which require to trigger a SPDT switch using a button to pass a small signal voltage across (~3.3V).
reference circuit image below enter image description here
The requirement is:
  1. signal must still pass through (pass through NC) even when relay/switch power is off (like what a normal mechanical relay would react)
Due to the small voltage, try to make it small & saving cost, I wish to avoid using mechanical relay. I found a SPDT analog switch TS5A3157 by Texas Instruments
My question is, will this IC work & pass signal to NC node when VDD is 0V (battery died). Or is there any alternative solution to do this?
share|improve this question
up vote 3 down vote accepted
No, it won't work when Vdd is 0V, the MOSFETs need a bias voltage to keep them open.
As Olin says it would help to know exactly what you are trying to do to determine the best solution, but for an electronic normally closed switch, here is a simple idea:
Most MOSFETs are enhancement mode, which means the MOSFET is off with 0V gate-source bias (Vgs) and turns on with a positive Vgs bias (for a N-ch, opposite for a P-ch)
What you need in this situation is a depletion mode device, which means with 0Vgs, the FET is on, and turns off with a negative Vgs (assuming N-ch again)
A typical JFET is a depletion mode device, and you can also get hold of depletion mode MOSFETs such as the BSS139.
So using something like the above, here is a simple circuit (that could be elaborated on if necessary):
N-ch JFET analog switch
Ignore the resistor R3, this is just to simulate a switch by setting it from low to very high impedance - the SWITCH node would be connected to your bias voltage needed to turn the FET off (so it's connected to -10V in this example)
Simulation:
N-ch JFET analog switch simulation
Above we can see the SIG_OUT when the JFET gate is left floating (Red trace) and then when biased with -10V (Blue trace)
The signal in is 200mV pk-pk with a DC offset of 0V, so this can be used for dual polarity signals. Depending on the JFET used, the gate does not have to be biased so low, the smaller the Vgs required to turn it fully off the better.
Note that the ON resistance of this switch will be quite high, so you cannot load it too much - if you need to drive something then you will need a buffer in between.
If you don't want to use a negative rail, the same concept can be applied to a P-ch JFET:
P-ch JFET analog switch
I haven't included the simulation as it's exactly the same as above. The bias voltage used was floating (e.g. if using a switch on the gate it's open) and +10V to turn off (so switch would be wired to +10V)
The FET part numbers shown can obviously be changed if desired, I'm sure there are better parts out there - they were just picked from the small selection LTSpice has.
share|improve this answer
thanks for the clarification. Also I had leave a comment on Olin's reply explaining where the application is intend to be use, hope you can give me some ideas – Dennis Sep 22 '12 at 14:07
Read the datasheet. It lists operating characteristics for several supply voltage ranges, with 0 V not among them. Therefore operation is not specified for 0 V supply, so there is no guarantee what you may get.
So from a design point of view the answer is no, it won't work at 0 V.
Olin, any alternative solution you can recommend? – Dennis Sep 21 '12 at 11:30
@Dennis: Step back and forget about this particular IC. Pop up one or two logical levels in your design and explain what you are really trying to accomplish. – Olin Lathrop Sep 21 '12 at 11:53
the application was meant to intelligently turn on/off a normal PC by tapping the push power button signal (which usually being connected straight to the motherboard's power jumper pin. In which a battery operated microcontroller sits in between the push power button and the motherboard power pin. At normal battery condition, push button signal is processed by the uC with some algorithm to decide whether is good to turn on/off the PC? if yes, uC will send signal to motherboard power pin and switches off the PC; if no, signal from push button should be ignore. – Dennis Sep 22 '12 at 14:04
In the event battery dies (uC will no longer functional), push button signal should be transparent and pass straight to the motherboard's power pin & turning on the PC like what a normal PC would behave. Hope my explain make any sense – Dennis Sep 22 '12 at 14:05
@Dennis: I don't understand what the micro is doing for you between the button and the motherboard. Doesn't it already work that way? On PCs I have, each push of the button toggles power on/off, which is what it seems you are trying to do. Also, micros carefully designed to sleep most of the time take so little power that the battery will outlast the PC. – Olin Lathrop Sep 22 '12 at 22:02
discard
