Tell me more ×
I am trying to program the Attiny84 using an Arduino(Leonardo). I have seen this Shrinkify video. -and I have been following this Programming tuturial.
I have connected everything. Using Arduino 1.0.1 software. Uploaded ArduinoISP to the Arduino. Selected "board" AtTiny84 (Internal 1 MHz clock). Selected "programmer" Arduino as ISP
When I try to upload the blink example, I get this error :
Binary sketch size: 880 bytes (of a 8,192 byte maximum)
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny84
avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check.
  • What am I doing wrong?
  • Should I upload by pressing "Upload" or "Upload using programmer"? (I have tried both - with same result)
  • What does "use -F to override" mean?
Update:
I have now found that my problem is that leonardo can not be used like this. I will investigate further.
share|improve this question
1 Answer
up vote 1 down vote accepted
PeterVH provides all the info needed to use the Arduino Leonardo as an ISP with the arduino ide (version 1.0.1):
ArduinoISP on the Leonardo
share|improve this answer
discard
