Tell me more ×
I developed a code in DEV C++ which simulates graphically a the actions of a train driver. Basically I control the speed and some other functions of a train from my keyboard.
Now, instead of the keyboard, I want to use a "home made mouse" i.e. digital/analog inputs to control the program.
Read some articles and seem quite difficult.
Can anyone help me with some advice, or point me in a few directions?
share|improve this question
You mean something like this? – Dave Tweed Sep 21 '12 at 19:22
1 Answer
Modifying a keyboard/mouse/game controller is a possibility for many projects of this type.
Or you could use something like an Arduino as an analog/digital input adapter. This would connect to the PC via USB, and generally would like like a serial port to your program. Your program would just monitor the serial port for data, which could be single bytes indicating various events, several byte messages, or even human-readable newline-terminated strings. The later can make debugging a lot simpler if you don't need to move so much data that you would fill up a high speed serial pipe. For example, your data might look something like this:
airbrake 0\n
throttle 10\n
throttle 85\n
whistle 1\n
whistle 0\n
Or for firmware simplicity, it might be something like
digital 3 0\n
analog 2 10\n
analog 2 85\n
digital 4 1\n
digital 4 0\n
Leaving your PC program to map the channels to names based on knowledge of the wiring of your adapter to the physical controls
share|improve this answer
discard
