I've heard rumors that the power line frequency is kept stable and accurate by syncing it with atomic clocks. Is this true? What kind of accuracy does it have? Is this true everywhere?
link|improve this question
55% accept rate
feedback
up vote 10 down vote accepted
Here's what wikipedia says:
Regulation of power system frequency for timekeeping accuracy was not commonplace until after 1926 and the invention of the electric clock driven by a synchronous motor. Network operators will regulate the daily average frequency so that clocks stay within a few seconds of correct time. In practice the nominal frequency is raised or lowered by a specific percentage to maintain synchronization. Over the course of a day, the average frequency is maintained at the nominal value within a few hundred parts per million. In the synchronous grid of Continental Europe, the deviation between network phase time and UTC is calculated at 08:00 each day in a control center in Switzerland, and the target frequency is then adjusted by up to ±0.01 Hz (±0.02%) from 50 Hz as needed, to ensure a long-term frequency average of exactly 24×3600×50 cycles per day is maintained. In North America, whenever the error exceeds 10 seconds for the east, 3 seconds for Texas, or 2 seconds for the west, a correction of ±0.02 Hz (0.033%) is applied. Time error corrections start and end either on the hour or on the half hour. A real-time frequency meter for power generation in the United Kingdom is available online. Smaller power systems may not maintain frequency with the same degree of accuracy.
link|improve this answer
UK power line frequency meter, pretty interesting – Nick T Dec 13 '10 at 17:10
feedback
This thread indicates the frequency may vary from 59 to 61 cycles during the day, but midnight to midnight they adjust the frequency to be exactly 5184000 cycles per 24 hour period.
There are also three (or four, not clear) separate grids in the US that do not maintain a phase relationship between them.
So -- short term timing (e.g. a few minutes or a couple of hours), within a fraction of a per cent. Long term, very accurate.
feedback
or
required, but never shown
