Tell me more ×
I need to create a network with 6LoWPAN, or maybe some others supporting IPv6, and are looking for development kits.
The ones I found are
I would also like input on projects available that I can get some inspiration from. Thank you!
share|improve this question
closed as not constructive by Leon Heller, W5VO Sep 28 '12 at 3:09
As it currently stands, this question is not a good fit for our Q&A format. We expect answers to be supported by facts, references, or specific expertise, but this question will likely solicit debate, arguments, polling, or extended discussion. If you feel that this question can be improved and possibly reopened, see the FAQ for guidance.
Companies offer development kits that can help developers kick start a 6LoWPAN project or just investigate its capabilities. Sensinode (www.sensinode.com) offers a K210 6LoWPAN Devkit and Atmel (www.atmel.com) provides its 2.4 GHz Evaluation and Starter Kit (ATAVRRZRAVEN) that runs a port of the Contiki 2.2.2 OS, which contains the small uIPv6 stack and SICSlowpan 802.15.4-over-IPv6 compression (http://www.sics.se/contiki). Arch Rock (www.archrock.com) has a PhyNet OEM Development Kit (IE version) that comes configured with the PhyNet IE Engine that lets developers use direct C API calls to the Arch Rock IP/6LoWPAN linkable kernel library to access operating-system services and standard TCP/UDP/IP-based networks. Jennic (www.jennic.com) also offers a 6LoWPAN Network Protocol stack that operates with the company's JN5139 wireless microcontrollers and modules.
You can check tutorials at
  1. http://www.cs.berkeley.edu/~jwhui/6lowpan.html
  2. http://processors.wiki.ti.com/index.php/CC-6LoWPAN
  3. More About 6LoWPAN
share|improve this answer
Sensinode is only available on TI's CCxxxx parts, so that I knew (as posted in question). Raven is only 2.4GHz, so is Jennic's and archrock's devices. While the tutorials are nice, I would like some more sub GHz solutions – Wilhelmsen Sep 27 '12 at 14:48
CC-6LOWPAN-DK-868 Kit is 868/915 MHz development kit...I dont think you will get something at 1 GHz(until you plan to tweak it yourself).IEEE 802.15.4-conformant devices may use one of three possible frequency bands for operation.(868.0-868.6 MHz,902-928 MHz,2400-2483.5 MHz) – perilbrain Sep 27 '12 at 15:10
I said SUB 1GHz, i.e 868/915 MHz for my part – Wilhelmsen Sep 27 '12 at 15:13
ZMDI's ZWIR4512. Stuff here: http://www.zmdi.com/products/rfid-wireless/zwir4512/
Thank you Mark! – Wilhelmsen Sep 28 '12 at 8:01
Please add some details here; when that link dies your answer becomes useless. – stevenvh Oct 1 '12 at 9:40
