I'm working on a lab for a course I have on VHDL, and part of it is to implement an n-bit ripple carry adder and then test it as a 16 bit adder. My problem is that I don't really know HOW to test it, or rather what inputs to give it to test it thoroughly. This is the first time I've ever done anything like this so I'm sorry if it comes across like I have no idea what I'm talking about.
My first thought was that since the adder is just a bunch of identical full adders chained together, if I could show that the individual adder blocks work fine, then it would be trivial to show that the 16 bit adder worked properly since it has such a simple design. So my two inputs would be XXXXXXXX01101010 and XXXXXXXX01011100 with an initial Cin of 0. Using these initial values, the first 8 adders in the chain would each perform a unique addition (as a function of both inputs and Cin) which would fully cover the truth table for a full adder. So if the corresponding bits in the sum are correct and the carry doesn't screw up along the way, it would show that the adder works properly.
I have a bunch of reasons to think this is the wrong approach though. First off, it just seems too simple. The lab manual refers to test CASES, but obviously I've only done one case. It also mentions that you should get timing information from the simulation, but I don't understand how that would work with only a single case. And most importantly, the strategy just doesn't make sense to me. All I'm really doing is finding a really awkward way to test a full adder by chaining a bunch of them together and forcing the Cin for each test case to be linked to the previous test case. I'm not testing the functionality of the whole thing.
As you can probably tell I'm pretty confused. I don't really have any idea how to properly test a 16 bit adder aside from testing the individual parts making it up. Should I just treat it as a black box and only concern myself with the final carry out and sum? But since the sum is 16 bits, how much testing do I actually need to do to show it operates properly?
