Tell me more ×
Our team (three hobbyists now developing our first serious device) is interested in soldering/assembling approximately 200 PCBs. We've already found a low-cost manufacturer for the raw boards, so just the assembly remains.
We'd like to keep the total assembly time and cost reasonably low of course, and therefore are considering various approaches.
The numbers are as follows:
  • 200 single-sided PCBs
  • 5 cm X 5 cm board size
  • 30 capacitors and resistors (0603 size)
  • 5 components QFN / QFP
  • 4 components SOIC / SSOP
  • 1 USB connector
  • 1 SD-card-socket
The raw boards may come bunched/panelized as manufactured but essentially, we want to get, on average, each individual board done in less than 20 minutes ideally.
Which one of the following options would you suggest as best? (given the cost constraint and the desired time per board I stated above):
  • Option A: Hand-place components with tweezers, solder resistors and caps with iron, and solder QFN's with hot-air gun ?
  • Option B: Apply solder paste (possibly using a stencil), hand-place components with tweezers, then use a toaster/reflow oven ?
  • Option C: Get it done entirely by an assembly shop ?
Note: All three of us in the team have roughly around 6 months of consistent experience with the traditional soldering method (tweezer, soldering iron, and hot-air-gun). We don't mind any necessary hand-work at all because we're definitely excited about our board, but it would be good to know we're choosing an efficient approach.
share|improve this question
I would suggest B. We do this in-house, and it's a lot faster and better than A. C can be expensive. – Rocketmagnet Sep 28 '12 at 13:22
@Rocketmagnet: By better, do you mean more accurate too? I've only done hand-placement till now, but in Option B, does QFN and SOIC placement have to be very precise at the pre-oven scenario? I guess I'm indirectly asking what kinds of durations you log for the placement phase. – OrCa Sep 28 '12 at 13:27
Employ teenagers on lose change wages! – TFD Sep 28 '12 at 13:29
SOIC is simple. You don't have to be accurate at all. The chip will self align. With QFN, you have to be a little more accurate, depending on the pitch of the package. It's worth investing in an eye lens. – Rocketmagnet Sep 28 '12 at 13:55
SSOP gives you slightly better visibility than QFN, and it's easier to fix shorts, even with a slightly blunt soldering iron. – Rocketmagnet Sep 28 '12 at 14:19
show 2 more comments
up vote 5 down vote accepted
C: definitely the assembly shop, if you have the wallet for it. That's for you to decide. Ask some quotes, and decide if doing it yourself is worth the effort. Since this is a hobby project you may think your time is free, but then it has to stay fun as well, hasn't it?
edit
Just got this in a mailing from DesignSpark: fundraising may get you started to have it done by a shop. Erik raised 313 218 dollar for a 5 000 dollar target.
(end of edit)
Alternatively, B: Again, get a quote for a stencil. Yet, even applying the solder paste manually will take less time than hand soldering, which I would not recommend: the resistors and capacitors are not much of a problem, but the ICs may take quite some time if you want to do it proper, i.e. all pins soldered and no short-circuits.
Not A: it takes too long and it's messy. I would only do it myself if I could use the oven.
Remember that Jobs and the Woz also hand-assembled their first batch of Apple computers :-)
share|improve this answer
The last line "changes everything" ;) Suppose we were to hand-place and toaster-oven them: In your experience, does less than 20 minutes seem like a likely average for the component count I listed, once we get into the loop? I'm especially curious about the placement time, because I don't know how accurate the placing needs to be before the oven. – OrCa Sep 28 '12 at 13:21
@Orlando - With the right amount of solder paste the parts will pull themselves to their right position due to the paste's capilarity, so half a mm off for the 0603s shouldn't be a problem. You can save a lot of time working on one panel at a time (or half a panel if the full panel doesn't fit in the oven): place all R1s on the different PCBs, then all R2s, well work as much as possible with the same tape&reel. The oven takes a long preheating, so you 'll have to interrupt the placement to check whether you panel is done. This may lose you some time, but esp. on a panel 20' should be fine. – stevenvh Sep 28 '12 at 13:30
But when the first Apple computers were made, the components were large enough to be used as bookends :) – Lundin Sep 28 '12 at 13:31
Options A and B: No, forget it! You will certainly screw up multiple of the QFNs/QFPs ending up spending far too much time trouble-shooting the boards for it to be worth it, even for a hobbyist. Down to 0.5 pitch QFPs are possible to solder by hand if you are good... SD connectors may or may not be possible depending on pitch. QFNs will only cause you trouble.
I have people with many years of soldering experience at my disposal, but each time we want to be cheap and do things like this ourselves, we get problems, ending up with something crappier and more expensive than what we would have gotten from the professionals.
There are always plenty of local, small SMD assembly companies that would be happy to do jobs with this volume for a reasonable price. Don't go ask the big dragons.
Hmm; what's a reasonable price? We got quotes from a couple of companies that stated around 13 USD each. Obviously, that isn't justified if we can get it done ourselves in less than 20 minutes per board. But on the other hand, we would put greater priority on staying away from the QFN/other inaccuracies that you stated. – OrCa Sep 28 '12 at 13:30
@OrlandoCastillo If you are taking option A, we aren't talking minutes, but hours. Option B would perhaps be possible, but then it all depends on how fine-pitched the components are and how experienced you are at doing such solder jobs. Without knowing anything about the US PCB assembly market, 13 USD sounds a bit steep to me. But since most of the cost is the machine setup: if your BOM contains lots of different values, then the price might be justified. – Lundin Sep 28 '12 at 13:46
discard
