Is it necessary to have impedance matching for short PCB traces if the frequency is lower than say 100MHz ? I've read somewhere that for a trace to be considered a transmission line it should have a length greater than 1/8 of the wavelength of the frequency, and somewhere else greater than the wavelength, not sure which one is more accurate ?
Anyway, assuming that it's 1/8 of the wavelength, at 100MHz the wavelength is 3000mm so it's not necessary to match the impedance for traces shorter than 375mm (3000/8), am I correct here ?
