Tell me more ×
I'm going to interface a 5V CMOS DSP to the 3.3V Flex 6000 FPGA.
This FPGA supports 3.3V and 5V IO according to the below figure from the datasheet:
Multivolt IO
Since the FPGA I found in stock is the 3.3V version, I must connect VCCINT and VCCIO to 3.3V. The minimum Vih of the DSP is 2V. Is it safe to connect both devices together? I'm afraid this 1.3V (3.3V - 2V) isn't enough to avoid ripples or ringing effects on the signals.
share|improve this question
1 Answer
up vote 1 down vote accepted
That should be fine.
(If you have 1.3V of ripple or ringing you've got really big problems that need fixing before you should think about transferring data over those signals!)
share|improve this answer
discard
