Tell me more ×
I am having trouble figuring out how to add voltage regulators to my circuit for SPICE simulation. The regulator is a 78L10AC voltage regulator, 10V, 5% output tolerance, LP package. I have most of my circuit figured out (I think), but am unsure as to how to write the statement for the voltage regulator.
If anyone could help me out a bit that would be great. Also looking for any recommended reference for SPICE software. (I have never used this before). We have a bunch listed that we can use, just want to see if anyone has a highly recommended, preferred document that they use as reference.
I will most likely be using LT Spice or PSpice. (any recommendations there?)
share|improve this question
1 Answer
If you mean how to write the netlist, then it will be something like:
XU1 N001 0 N001 N002 +10V LT1761-SD
The above is an adjustable regulator with 5 pins (IN, OUT, GND, ADJ and SHDN)
It's a subcircuit, so it's declared with an X. Also, since complex subcircuits are usually written in a separate file, you need to make sure the subcircuit file is included in the netlist with a declaration like:
.lib LT1761.lib
Alternatively you can add the subcircuit code directly into the netlist.
I would recommend LTSpice, it's an excellent, easy/quick to use and powerful free SPICE.
share|improve this answer
discard
