I was doing some measurements for a coursework. Op-amp, LM741 in an x10 inversor configuration.
When the resistances in use become high enough, 1MOhm and 10MOhm, the output is correct but it has a 50Hz noise on top, of amplitude that would suggest an extra 80nA through the resistors. That effect isn't seen while simulating on PSpice, but it is expected behaviour since other people measured it too.
Now, the datasheet gives 80nA as the bias current, so I, who still don't know much of how an op-amp works internally, suspected it was to blame. However, I've been told that the bias current is always DC so it can't have anything to do with that, and that it has to do with something acting like an antenna, but no clear explanation was offered to me. Is that true? I have no clue what's going on and would appreciate orientation
EDIT
The objective is just educational, it's to understand the behaviour. With 1k-10k resistors it works perfectly. 50Hz is the mains frequency so the noise is surely somehow due to that. But I'd like to know more why that noise happens, how to model it in a way that it explains the fact that it's there with 1MOhm resistors but not with 1K. Also, if it's related to some parameter in the LM741 datasheet that explains the amplitude of the noise
