I seem to be going through soldering tips at a breakneck pace. Four or five hourly sessions, and it's corroded all to hell.
Does this sound about right, or is there something I should be doing differently? It's a standard 40 watt cheapo iron.
I seem to be going through soldering tips at a breakneck pace. Four or five hourly sessions, and it's corroded all to hell. Does this sound about right, or is there something I should be doing differently? It's a standard 40 watt cheapo iron. |
Here are some tips for maintaining your tip. http://chiphacker.com/questions/216/soldering-iron-maintenance |
Plated tips last longer ( much longer ) than unplated. Also a thermostatically regulated tip does not overheat and eat the tip. Just a couple of tips. |
One thing I haven't seen mentioned yet is this: Whenever you are planning on not using the iron for more than about a minute, load the tip with solder. This way, the solder oxidizes in the air, instead of your tip. An unprotected tip will start to oxidize pretty quickly in air, and the longer it is allowed to do so, the worse it gets. When you are ready to use the iron, do the following:
Tips oxidize dramatically faster when they're too hot, so check your temperature if you can. |
Tell us more specifically what kind it is. Our Wellers were burning up from the temperature sensor malfunctioning. They use a magnetic sensor, which we think were ruined by soldering next to the big magnets of loudspeakers, so they were permanently magnetized and stayed on perpetually.
http://www.electronicspoint.com/weller-soldering-iron-sensor-t49505.html |
Okay, basics:
Two things I have experienced:
